Question on the relay switch for the clutch bypass
Ok I'm finally going to take the plunge and do the clutch bypass operation on my ZR-1. I read through Crabs' 5 year old thread on the "Dreaded No Start Fix"
http://forums.corvetteforum.com/c4-z...hopefully.html
As I see it, his fix is to completely bypass not only the clutch switch but also the start delay relay. Great idea! Now to the relay switch he used. It looks like you can get away with a SPST (Single Pole Single Throw) relay with 4 connections versus a SPDT (Single Pole Double Throw) relay with 5 connections. I say that because it looks like the relay is only feeding voltage when it is closed and not when it is open. Now where's the best place to buy the relay? I'm thinking if I walk into an autoparts store and ask for a relay, their first question is going to be "what make and year is your car?" And their second question is going to be "what part do you need for your car?" Since this relay is NOT a stock part for the car, those questions are irrelevant. I know the relay should be a 12v 30/40A one but where did everyone buy theirs?
Pretty sure that I got mine at Radio Shack........
I did this mod about 2 years ago, and haven't had a no-start problem since then. I picked up a fog lamp relay that was good for 30 amps at the local Autozone. It had four male spade terminals, which makes connections easy. I attached it to the fenderwell liner using a screw and j-nut on the mounting tab built into the relay. I picked up my battery (+) feed off the junction block just aft of the battery. Be sure to install a fusible link or inline fuse in this wire, or a short will cause a serious fire!
And I found the relay at Radio Shack just as Bobby said
