mechanic/shop
1994 Admiral Blue ZZZZZR1
What do you need done?
Many things can be done by any mechanic and it might be a good idea to get ideas first.
Aaron Scott isn't that far.
http://www.sgvette.com/about.htm
I would post up on this forum first and get a diagnosis:
http://www.zr1.net/forum/
How long have you had the car? Have you done any work on it recently?
David
David
The last thing done was a replacement of the master cylinder about a year ago.
I've had the car for 4 years - no problems until now.
The car seemed to have a vibration which I thought was an alignment problem.
I drove the car to work last Friday - a little vibration, but otherwise OK.
the vibration seemed only to be noticable above 55 mph. In town, no problem.
Any way I got off the I-75 and all at once it seemed like I had dead miss. I don't know if that's what they still call it - been a long time since I twisted any wrenches.
I made it home - smelled a little like rubber and sounded like it had a
knock about halfway down the passenger's side head.
Any suggestions would be appreciated.
Thanks for responding.
I agree with Johnny, especially if your car is a 90-92 and still has the original injectors. Does the miss/knock become worse as the car warms up to full operating temp?
You can check injector coil resistance easily yourself, without removing the plenum - check out the procedure Marc Haibeck describes in this article: http://www.zr1specialist.com/HAT%20W...in%20Place.pdf
I only noticed the miss/knock when I was about 2 miles from home - it was the first time it happened. Just the vibration previous to that.
I was accelerating after leaving the exit ramp when the miss started.
It is a '92 with the original injectors. About 36500 mi.
Would it be prudent to replace all the injectors?
David
