power steering pump removal
I need to replace my power steering pump. Removed the air filter, belt, throttle body air horn, and the bolts that attach it to the engine. How do you get the pump assembly out?
Do I need to remove the top radiator hose and the coolant cross over tube?
Where should I disconnect the high pressure line and return line?
Thanks in advance
Charley
Thanks in advance
Charley
Hi Richard
Very seldom drive the car. Second time out this year. The steering got tight and noticed vapors. Looked under the hood and fluid on the pump pulley and below in front of the motor. The reservoir was empty. Drove it home. Couldn't find any problems with the three hoses. I refilled the reservoir and started the motor. Some fluid blew over the top of the left tire. Shut the car off. There was fluid on the front of the pulley again. There is a considerrable amount of fluid on the garage floor. Could the rack be bad? How could I check that?
Thanks again.
Charley
Thanks again.
Charley
If you can wait until this afternoon, I'll take a look at mine to help figure out the source of the fluid spraying over the left tire. Definitely sounds like an external leak though...hydraulic pumps rarely go bad which is why I was asking.
Could the rack and pinion have blown a seal and then the steering pump went dry? What's the procedure to determine if the rack and pinion is bad? Car has 17,000 miles.
It's possible the rack and pinion blew a seal but not likely. I looked at my car and for the fluid to spray across the left tire, it's more likely a hose has failed or a fitting has come loose at the rack and pinion. Either way, you'll probably have to remove the pump to change/tighten the hose but better to change the correct part the first time.
Richard
Removed the pump today. The serpentine belt wore into the high pressure hose. Sure glad you were again correct regarding the rack and pinion.
How can I determine if the power steering pump is still good?
Thanks again.
Thanks again.
A new pump is fairly inexpensive but let's keep our fingers crossed.
Once you have the new hose installed, might as well change the fluid.
Best to put the front end of the car on jacks, and with the engine running, turn the wheel from stop to stop as many times as necessary to remove the air from the system. You'll need a suction device to pull out the old fluid and keep replacing it until it remains relatively clear after several stop to stop cycles. (A turkey baseter works good to remove the old oil, and they come in handy for brake servicing too)
You'll need to rent or fashion a jig to press the pully back onto the pump. The FSM shows a diagram and using a special gauge. However, I was able to use a straight edge across the A/C pully and the PS pully and get it "perfect".
Good luck. I assume the hoses will be secured away from the belt this time, huh?
P.
P.
P.
P.
I ordered a new high pressure hose from Advance Auto Parts. Should be here tomorrow.
Richard, Good suggestion regarding changing the fluid.
Paul, I was just going to leave the the belt off. That way no worries of it cutting the hose again.
Hopefully, I'll get it done in the next three or four days.
Thanks again.
Thanks again.
With the pump and hoses already off, the best way to change the fluid is to turn the wheels hard left and then hard right to expel most of the fluid from the rack piston/cylinder. The fluid is already out of the pump/reservoir, no sense in making the job any harder than necessary.
I wuz going by the FSM when I did mine, but thanks for that tip!
P.
