C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
LT5 Cooling Parts Assortment
Old 04-28-2016, 04:51 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
Default LT5 Cooling Parts Assortment
GM cooling parts for LT5. GM parts. Stored indoors.
Upper Radiator Shroud
10265847, support, upper radiator, new
SOLD
Engine Oil Cooler Kit
10219643, cooler, engine oil, all-aluminum sevem-tube, second design 94-95, used, good.
10219644, hose assy, engine oil cooler, second design 94-95, used good.
The 2nd-design cooler, made by Fluidyne, is a performance upgrade for 90-93. It offers improved oil cooling for early engines.
SOLD
Old 09-05-2016, 11:19 PM
Dominic Sorresso
Dominic Sorresso's Avatar
Hib, u don't happen to have just a stock thermostat do you?
Old 12-09-2016, 11:46 AM
Hib Halverson
Pro Mechanic
Pro Mechanic
No. I don't. All my 'stats went to the new owner, when I sold the car.
Also....sorry to take so long to reply to your question, Dominic.
Old 12-09-2016, 12:04 PM
Dominic Sorresso
thx Hib. Bought one and it seems to have done the trick.
Old 12-11-2016, 11:51 AM
Hib Halverson
Pro Mechanic
Pro Mechanic
Glad you got the problem solved, Dominic.
Old 12-11-2016, 03:16 PM
Dominic Sorresso
Hib,
The issue was that I had installed a Fluidyne rad. Whenever ambient temps dropped below 60F, I could not keep heat in the motor causing it to drop into Open Loop. The issue was that the thermo installed has 4 bypass holes drilled into it. I installed a thermo w 2 holes and now the temps stabilized coolant temps at 186-192F.
So thanks for getting back to me.
To LT5 Cooling Parts Assortment
Quick Reply: LT5 Cooling Parts Assortment
