Relieving secondaries of duty
My 91 has the following mods...OBX Headers, exhaust,ported plenum, air horn, injector housings, Haibeck chip....K&N filter,hurst shifter...
I hear and have read that if you relieve the secondaries you will feel " seat of the pants performance "..
Anybody have my set up than have relieved secondaries?
Does it need a retune if this is done ?
Rich
What Scrrem said. I eliminated my secondaries back in 2003 because I got sick and tired of chasing vacuum leaks. I recall the ZR1 Net Registry did an article on making brass hoses for the vacuum system. For someone who isn't going to do a chip tune, it would be a good idea to look into. For tuners, easier to eliminate them.
One of the best mods I ever did on my LT5. Throttle response is instantaneous, the intake valves both stay clean, NO more secondary vacuum issues, NO downside. What's not to like?
I pulled the entire mechanism and Marc provided a chip modified for "secondaries deleted"; a canned tune that sufficed until I later ported the heads and Marc finished the project off with a dyno tuning. That was 5 seasons ago - no issues at all.
I also did what Paul did--had Marc remove the secondaries when he did his 510 HP package on my '95, and I am very glad I did the mod. No vacuum headaches anymore and fine performance. A note of caution, however. What Marc does is he sets the primary and secondary injectors to each operate at 50% flow when the secondaries would not otherwise be operating, as opposed to the stock set up with the primaries at 100% and the secondary injectors off. So together they provide 100% of the fuel needed for lower rpm operation. As a result, you should never run the car in "Normal" mode, only in "Full" mode, as you would be running too lean at lower rpms. I simply set my car in "Full" mode and removed the Power key. I also attached a key chain tag to the Power Key noting the car has modified injectors and should never be run in "Normal" mode. Hopefully the new owner will pay attention--Bob
