New ZR1- are these Knits easy or hard?
Zen Vet Master Level VII
I picked up my new (to me) '91 ZR1 in Akron Ohio yesterday (Oct 28) at 9 am and arrived at my home near Ft Worth Texas at 1:30 am after 1183 miles. Love the power road trip and the car was fun. Drive train, trans, brakes were flawless. Really liked the was the car drove. It was a blast.
I do however have a few knits that I need to work on. I ordered all the service manuals, but they have not come in yet. I'm not sure these are easy fixes, common stuff or harbingers of crazy. Mind you the dealer told me (after exhaustive conversations) that EVERYTHING was in perfect working condition.
1) AC. Nope, nada nothing. All the vents worked and the heat came on but no cold air just vents. My guess is that the system is low on 134 and that the compressor did not come on as a fail safe? Also, the vent air speed changed with the setting but I never got that usual "WHOOSH" of air flow at the high settings like my 82? Is that normal? I actually have it at the shop getting a evac and fill even as I write.
2) Radio. Again zip. I have the Bose Gold cd/cassette and the piece turn on, channels scan, buttons work but no sound. Just a faint crackle. Is there missing fuses, amps, etc that are easy fix or is it something larger?
3) Suspension Service light. The light came on after about 150 miles for no apparent and stayed on till about 900 miles. It did go off after I used the brakes hard to avoid an idiot near Little Rock, AR. I have it set on the middle setting. Whats that about?
3) Tire pressure warning system. The light comes on after a about 15 miles and stays on unitl restart. This morning I checked the pressure (new tires) and it was 2lbs off on the front and dead even at the rear. Will 2 lbs throw the system into a fault or is there something larger going on?
All in all, I love the car, it is a one owner and I have all the docs including original bill of sale.
Thanks for the help!
The amps in the speakers are bad and most likely the lumbar bladders in the seats are toast as well. The CDM controller for the stereo goes bad in some. That's just for starters.
If it's a 91 then it's R12 unless it's been converted. May have a bad compressor or leak. Is the green LED flashing on the HVAC head unit? Usually that's means low on freon.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
Look at Cliff's (Dynomite) links "solutions" to find out about all of your issues.
You can give it a charge yourself by hot wiring the ac cycling switch
See Item #4 R12 vrs R134a and recharging R12
The low tire pressure warning system- it is entirely possible one or all of the wheels don't have the sensors anymore. Those are garbage anyhow. I had mine working for a few years, but gave up on them. Always you will have one corner lose communication and the light pops up. I mean, it can work, but I would just pull the lamp out of the display.
The FX3 suspension...well, maybe one actuator or shock is bad. Some people also say adios to FX3 suspension and remove the bulb... unless you find you only need one single part- you will have to assess the cost and decide.
CD player- broken on every C4 just about, but the radio might still work- you just have to figure out if the speaker amps are shot. Try a cassette tape- If you get some decent audio from that, it may mean the tuner is bad (which is a separate box under the passenger airbag). See Cliff's solutions link for how to get amps for cheap.
If the ZF transmission is solid, you should be alright.
I feel like I'm living vicariously through you. I'm exited hearing your story and experience anticipating what mine will be like. I'm glad you like it but if you ever decide to trade I would love to have first dibs because it's exactly what I was looking for. Keep the stories coming I'm really enjoying them!
2015 C4 of the Year Finalist
St. Jude Donor '16
Congrats, Hope you have many miles of smiles.
Thanks for the tip!
The shock valving might be stuck on soft- if you ditch the FX3, you need to replace the shocks. If you can read the codes, maybe you can find out how many problems it is reporting and try to fix it. The FX3 is ok to have when it works.
Thanks. I'll keep that on the list-I'd love to get everything working (cant wait for my shop manual. Tuesday delivery)
Now, I noticed a weird popping/crackling coming from the rear drivers wheel at slow speeds. It goes away when I shift to second and I can only hear it with the window down.
St. Jude Donor '16
