Injectors
Injectors
I have a friend with a 93 who needs injectors. I am wondering what the recommended injectors are these days. I know FIC has a set that looks stock. Is that the accepted best swap, or is there something else recommended (injector dynamics, etc...)
I've had the Accells in my '90 for 5 or 6 years, no troubles.
About a third the cost of the RC's.
Similar price as the FICs.
Do NOT, repeat, DO NOT even think of buying NOS AC Delco Multec injectors. Even if someone gives then to you for free, it's not worth it.
'Crabs
'Crabs
I went with the FIC injectors and they're working flawlessly!
I actually bought a different set of Ebay before that and the minute I try to start the car, it sounded as thought it was running on four cylinders. Come to find out, it actually was! Four of those injectors were bad...had to pull the plenum more times than I wanted to...
I am about to list my oem 94 injectors if interested. Figured it would be ok to post in here, I went with FIC and they made no difference whatsoever. I ohm'd them all and they were identical on all (or very extremely close). I changed them just to change everything under the plenum.. I was bored
