90 ZR1 mufflers
90 ZR1 mufflers
The 1990 dk.red metalic / tan I just bought has a muffler coming apart on the inside so I am look to see what others may be using. I don't want anything loud or droning. Prefer pretty much a stock type replacement. Found a lot of louder reviews and drones but nothing much else.this is not a show car or points chaser. Pretty much a driver in nicer weather. Ideas?
I have a Flowmaster cat back system on my '90 and love it.
No drone, and although louder than stock, not too loud.
BB and Corsas tend to be louder at WOT, about the same at lower RPMs.
'Crabs
'90 ZR1 #792
'Crabs
'90 ZR1 #792
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Have Flows on my 93 Corsa on 91 No Drone on ether. You could always find 93-95 stock set-up better flow.
George45 (12-18-2016)
Zen Vet Master Level VII
I'm interested in this topic as I (continue my angst) want/need to do something with my stock '91.
I'm intrigued with the idea of removing the center resonator and replacing it with an "X" pipe. However I don't want any drone.
I'm not sure if to leave the stock muffler or swap them for something different?
Finalist 2020 C4 of the Year - Modified
I have Corsa on my 90. What I especially appreciate is that there is absolutely no drone. I can cruise and have a conversation with my wife. When you get on go-pedal, it's loud, but otherwise it's very civilized.
1994 Admiral Blue ZZZZZR1
Check that before you change the exhaust (if for that reason only). I think Corsa or B&B fusion are AWESOME upgrades with NO drone!
Good luck and curious to see what is actually coming apart.
David
I'd make sure that the Cats aren't coming apart and collecting in the muffler...
David
David
I have an NOS set of GM replacement ZR1 mufflers available if you're interested. P/n 12511525 and 12511524. Let me know.
My .02 from what I've learned about ZR1 mufflers...
There was a design change and 91 and up mufflers are more desirable as the 90 has an oval inlet (slightly restrictive) and the 91 and up are round, matching the exhaust pipes and with less restriction.
Also, the 90 and 91 resonators are very restrictive with the 92 and later years as almost zero drag. The inside diameter of the 90/91 resonator is 1 5/8 while the 92 and up match the exhaust pipes at 2 5/8. Marc Haibeck reports that the 90/91 resonator accounts for a -10 HP.
BTW... Chevrolet used the same 2 5/8 resonator on 92s on up. So an LT1, LT4 or a Zr1 resonator will work equally. I'm swapping my 91 resonator for a 93 version next Friday.
Might want to consider doing a twofer?
David
David
In either 1992 or 93 there was a redesign of the cat so this wouldn't happen.
