Lowering pkgs
Cruising
Lowering pkgs
Hey guys I got a c4 in good shape I'm restoring! But it sits a little to hi for my likings! Anybody got a recommendation for a lowering pkg?
Id tell you its low enough however coil overs is a good option and most of the major corvette aftermarket house have a rear spring lower kit available
Zzilla (04-17-2017)
Received 1,864 Likes
If you do a search in the C4 Performance forum, you will find all kinds of info about lowering your 91. Lots of photos of lowered rides,too.
Zzilla (04-17-2017)
Cruising
Lowering Pkgs
Ty! I've been browsing a little! Basically I've found that running longer
spring bolts should do the trick!
I just want to do it right the first time!
Zzilla (04-19-2017)
Zzilla (04-19-2017)
Cruising
I'm just starting to get into this puppy! I was not sure what pkg's are available for these C4's
Some Machines have adjustable ride height coil overs on all 4corners! I was hoping this C4 might have a pkg avail.
http://dougrippie.com/
Zzilla (04-20-2017)
Basically for a softer ride you would select "Tour" and for racing and hard cornering "Performance" setting was used which stiffened the ride. Back in the day it was pretty high end tech
