91 ZR1 Fuel Injectors
Have the car in the shop to change out starter that went bad. Since plenum will be pulled a good time to change out the original fuel injectors. Is this a pretty straight and simple task by the mechanic? Plug and play if you will while plenum is off. Thanks
Accel injectors, #150821 from Summit Racing.
There is a plastic nub that has to be removed on just half of them. (I used a Dremel); It takes about 5-10 minutes to do just 8 of them.
Mine have been running now for...6-7 years now. Good stuff!
Pretty straight forward,if the mechanic has any questions on the small parts look up JERRYS GASKETS. This look like fun?
I would like to label all the components in your photo.
Cliff
