Lo Mileage ZR-1s
Lo Mileage ZR-1s
Hi everyone. I'm looking at purchasing a very low mileage ZR-1, between 3,000-4,000 miles. I'm concerned that there could be maintenance problems with a 22 year old car that's been driven so rarely. Are there any issues I should watch out for?
Thanks for your help.
Barry
Barry
From my experience, the biggest issues depend on;
1. Year model, 90~92 or 93~95
2. Frequency of engine starts & the length of time & coolant temp achieved
3. Climate conditions, i.e. dry rot of rubber components.
* 90~92 models were not ethanol blended fuel tolerant & would likely need new injectors.
* Original tires would need replaced.
* Seat air bladders & air pump will generally need attention
If the car starts & runs like it should & there are no fluid leaks, then it is probably good to go, bearing the three* statements above.
Be sure to confirm there are no electronic issues. The LT5 is a favored area for mice to set up home.
Plan on changing all fluids & flushing coolant, brake & hyd clutch system.
Barry
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Good luck with your search, lots of great deals around you could almost say a steal....
