full power mode
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Two things come to mind secondary fuel pump or vacuum issues. You really need to hook up a scanner to see whats not working.
with all of the above. Just had that with mine, it was like the secondaries didn't work a all. Turned out to be a collapsing intake accordion. The one between the air filter housing and the throttle body.
I simply took the accordion off a drove it without it, what a difference.
I fabricated two Haibeck style hoops, put them in the accordion and reassembled. All good. Some times it's the simple things, sometimes it's not.
H
H
H
H
Just eliminated accordian
just eliminated accordion no change noticed that the power was good when the engine was cold worse when heated not that good even in valet. still hunting look for someone that can troubleshoot in my area I guess
Are the injectors stock? Mine is the same way, except there is a cluncking sound coming from under the car when in neutral, due to the engine misfiring from the injectors being bad. It gets worse as the engine warms up. No dash lights either.
I'd want to start with what the fuel pressure reads, ESPECIALLY at WOT. (Should read 52 ro 55 psi @ WOT, dropping back to atound 45ish cruising.)
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
I had an issue with injectors and fouled plugs (one begets the other). 4000 miles is pretty low, injectors rust and stick... I'd do a fuel system pressure bleed test and check all of the plugs.
How does it idle when it's warmed up? Does it bog under normal acceleration or once it passes a certain RPM?
Both fuel pumps run until about 176 degrees and then the secondary turns off until called for (WOT full power). See if starts running bad about 175 or so. Could be a week primary pump.
You can pull the fuses on each pump to check pressure from each.
