C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
High Side A/C Fitting
Old 07-13-2017, 06:52 AM
Scrrem
Scrrem's Avatar
Default High Side A/C Fitting
I have a 90 that is still running R-12 Freon. I have Freon and gauges but my the high side fitting is smaller that the low side fitting. My high side gauge connection is to big. Do they make an AN fitting adapter to make this high side gauge connection? I'm just not sure of what the size conversion I need.
Rich
Old 07-13-2017, 08:18 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
Rich
A 10468A Robinair is 3/16 FFL to 1/4 MFL and was used for maybe all '77+ GM R12 - if your gauge (female is to large I'd think this correct). A 10470A is with a short flexible hose.
Your post confused me just a bit as to what was larger/smaller. Is the FEMALE on the gauges "larger" or "smaller" than the line fitting?
Old 07-13-2017, 08:32 AM
Scrrem
Scrrem's Avatar
Sorry Dave, my gauge connection is too large for the high side fitting. So does that mean my high side fitting is 3/16 and my gauge connection is 1/4?
Rich
Old 07-13-2017, 08:41 AM
WVZR-1
WVZR-1's Avatar
Rich
This MasterCool might be an easier find 90355 - one of the three I mentioned should be available locally. I believe a friend has the flexible. I recall the "red".
Scrrem (07-13-2017)
Old 07-14-2017, 07:53 AM
WVZR-1
WVZR-1's Avatar
How did you make out with an adapter?
Old 07-14-2017, 09:01 AM
Scrrem
Scrrem's Avatar
Yeah found a solid brass one on EBay with cap for $6.00, should have it Monday. My system must have a small leak, replaced all the high side lines 3 yrs ago. I couldn't break the connection loose from the evaporator on the low side, didn't want to break the connector so left it alone. The O-ring is probably OEM and dried out, well I've got plenty of R-12....LOL!
Rich
Old 07-14-2017, 10:02 AM
WVZR-1
WVZR-1's Avatar
Rich
This adapter has the Schrader valve control also? Sounds cheap enough!!
Old 07-14-2017, 10:15 AM
Scrrem
Scrrem's Avatar
Yep. Has the Schrader valve also!
You going to make it to Carlisle this year?
Rich
To High Side A/C Fitting
Quick Reply: High Side A/C Fitting
