C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Upper shroud on a 94 ZR-1
Old 07-16-2017, 02:07 PM
limatangogolf
3rd Gear
limatangogolf's Avatar
Default Upper shroud on a 94 ZR-1
How to remove the upper shroud on a 94 ZR-1?
Old 07-17-2017, 12:28 PM
Scrrem
Scrrem's Avatar
There are about 5-6 screws along the top edge of the shroud and a couple along each side and 4 at the intake under the front bumper. Once they are all off, you will need to carefully raise the drivers side of the shroud and maneuver the passenger side from around the high side A/C line connector. You need to be careful because you can crack the shroud while doing this, ask me how I know... If you are patient and careful, it's not too bad.
Rich
Old 07-17-2017, 12:56 PM
Dynomite
Support Corvetteforum!
Dynomite's Avatar
Default Removing Radiator Shroud
See Item #2 Installing a Ron Davis Radiator and Testing
To Upper shroud on a 94 ZR-1
Quick Reply: Upper shroud on a 94 ZR-1
