Tech 1A adapter cable 02001744 or 02001969
Have a 95 ZR1 and have an opportunity to purchase a Vetronix Tech 1A scanner but it doesn't have the adapter cable for my car. It does have a Tech 1 OBD II VIM #3000091 but not the adapter cable. The 2001744 adapter should plug into this module or the 2001969 adapter should connect directly to the main cable in the scanner. Does anyone know where I can purchase one if these?
[QUOTE=Kropc;1595498778]Can you send a pic of both ends of your adapter. I am sure there are adapters only without the cable available I just don't have a part number. You just might have what I looking for. Your adapter would connect to the VIM module I have then to the car.
In this thread post#10.
This is the adapter I used for a '95 16-pin ALDL/DLC - it's used only for 16-pin NON OBD2 cars. I used it with a Tech1 -
https://www.corvetteforum.com/forums...post1568131767
