New to me 90 zr1
New to me 90 zr1
Just purchased from fellow forum member PhilipJFry his 90 black on black ZR-1...great having one again after 7 years..these cars instantly put a smile on your face..great dealing with Anthony on car purchase.
whichvette (11-04-2017)
Car has 34.5k miles....it came with a corsa exhaust that I will probably put on soon...but i kinda of like the quiet for now..orginal pizza box along with receipts from all owners...car has a large spider crack in paint..which is going to go bye bye on Tuesday
Zen Vet Master Level VII
Well done!
As you consider exhaust modifications, Marc Haibeck put a study together...
http://www.zr1specialist.com/HAT%20W...%20Systems.pdf
Your resonator is the biggest bang for the buck. Couple it with a Haibeck chip and you got some cheap, easy gains.
Glad you are back in ThunderDome
Well done!
Had Corsa’s on the last Z. It is interesting on a Z. Relatively quiet under most conditions but when you get into the throttle, it screams like banshee. Some people like the sound others don’t. I loved it.
If you don’t use the Corsa mufflers and take the resonator out you will end up with very annoying drone. Been there done that.
H
H
the corsa muffs are much better than oem so most of the gains would be negated.
I'm partial to the b&b with x pipe. the LSV sounds SOOOOO good with that exhaust
I'm going to try adding the "flappers" on one side to go mild to wild but honestly it's quiet enough in most crooze scenarios and absolutely feral when provoked.
I did a few 8k pulls yesterday and the old 390 still gets it.
Thanks Demps for the tuning!
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Nice and congrats Black ones look so cool.
whichvette (11-05-2017)
The Corsa system works by using a cancellation technique and has the advantage of very low restriction.
The full range of in-cabin resonant frequencies requires BOTH the resonator AND the muffler working in random. If either the resonator or the muffler is removed, the best analogy might be like maxing either the bass or the treble on the sterio player. At best the sound will be affected; performance too may have some downside as well...IDK.
Try it and see!
Try it and see!
Try it and see!
Try it and see!
Finalist 2020 C4 of the Year - Modified
Congratulations. Nice looking Z. I love black (when it's clean )
It's good to hear you had a good experience buying from another forum member.
Thank you .Going to put corsa exhaust on..I tried the dupi color blackshadow...but it came out like garbage. .so getting the tips ceramic coated black..I was going to get them powdercoated but im seeing that ceramic probably lasts longer..
St. Jude Donor '16
I got them with the black tips.
