Samco Hoses...
Samco Hoses...
Anybody got a set of Samco hoses they are willing to part with? Mine must be close to 20 years old... time to replace them before I have one fail.
I prefer they be red in color.
No way of really knowing how long they will hold up until they blow. Why take a chance after 20 years? A little preventative maintenance can go a long way toward preserving a glitch free ride year after year.
True, but I was under the impression silicone hoses won't fail unless you cut them. I have Samco on my LT1(not an LT5, I know) and to be honest, I just like how they look. Best of luck on your search
LT1 or LT5 makes little difference... heat cycles and cold cycles tell the long term durability story... so... drive on and enjoy... and do your preventative maintenance when you think the time is right and you are motivated to go through the hassle of doing it... on my car... its a painfully slow process. I do it anyway because I love my car!
good question on how long they will last! Jerry now has the hoses that don't have the durn samco letters all over them
I'm going to upgrade the fans soon so if you want my samcos, let me know
for 160, I'd put new ones on. I had an old ford guy tell me that the silicone hoses will "last longer than the engine" Those hoses last and don't break down like the rubber, how long???, that's a tootsie roll question!!!
I have to admit... I did have an elbow hose on the drivers side start leaking and I replaced it with new rubber hose.
I'm going to put some dewitts upgraded fans in the car clean er up and probably go with Jerry's hoses as I'm not a fan of the samco logo
the other problem is the inlet duct, "pooches out" just a bit straining with all that cfm and rubs ever so slightly on the hood
just enough to leave a little black streak
that being said, the hoses ARE awesome and popping a coolant hose is a real problem. the rubber stuff IS getting old if you haven't changed them. just like tires, hoses are a service item.
with the silicone stuff though, that interval is WAY longer.
My bet is the samco stuff or mitsu silicone hoses will outlast me.
the samcos are a definite PITA to install. I've had some "coolant weep" ever since I installed mine and the leak is getting annoying
As a side note watch your wires under the battery that feed your fans. Mine deteriorated to the point of having to replace them. Its seems that area under the battery is a corrosive area for wire and insulation.
I have no idea why because I have run 2 optima batteries over the last 14 years and didn't think they emitted anything hostile to the wiring.
Leave it to me to brag about a part. I was driving the LSV yesterday (bad day) and the upper hose coming off the engine split and dumped the coolant. I saw the low coolant light come on and the "death plume" rise from the hood and pulled off into an industrial park. At least it was easy to get to! Pulling the LSV on the lift the ramp caught on the front fascia and gave it a nice tear. I almost fainted. Oh well it will all fix.
sheesh!!!
sheesh!!!
sheesh!!!
sheesh!!!
My conclusion... this is the area inside the hose that is getting the brunt of the heated coolant flowing directly at it from the coolant tubes.
It is also the area where the hose is probably the thinnest due to the hot stretching that occurred when the hose was heated and formed.
I ordered a new set of mitsus and will give them a try
I'm going to service the cooling stack as soon as all the leaves are gone
anyone have a spare 90? I found stock hose and cut it up to get the 90 deg elbow so I can keep driving the car (I'm off right now!!) and it must be slightly too big inner diameter as it leaks.
thanks!
thanks!
thanks!
thanks!
Pm me with the address and I can get it out today...
thanks for the offer but the old LSV is running on a hacked up rubber hose
sheesh they wanted 40 online. I found an S hose off a whatever and cut in half and it's perfect for this application and cost me 12
the mitsus are 160 which is a pretty good deal
Any hose that fits without leaking is a great hose! I will be upgrading soon... maybe Santa will bring me a set!
this is one time the cost went down not up
I think the samco set was 224 on sale
I had some "coolant weep" smell ever since I put them on so the radiator is coming out for service, upgraded fans going in, and the new mitsu hoses
meantime I have the old dayco hose one there and finally got the lt5 to "burp" and get the engine back full of coolant
I put the rear of the car up in the air and had to waste a bit of coolant as when it bubbled up I popped the rad cap off (not tight)
took a few tries to get her full but she finally settled down
well the mitsus came and look good. I'm going to pull the rad and put some upgraded fans on the car at the same time
the zr1 is getting some runs before the winter nap
we had one small snow and salt already tomorrow it rains and we'll have snow maybe again on Christmas
have a merry one.
have a merry one.
