ZR1 mechanic/shop in Sarasota/Tampa area?
I am getting towards the end of my wits and my skills on this secondary issue. If it is not the fuel filter or the vac secondary pumps I am out of ideas and parts to replace. If anyone has a reputable ZR1 guy/gal they can recommend in my area, it would be greatly appreciated.
Do a Secondary Functional Test with Key On by grounding the pink wire with black strip on ECM and observing Secondaries function between the Plenum Runners
Secondary Functional Test and Reconditioning the Secondary Actuators
Aaron Scott at SGC is nearby in Thomasville GA
Also Kurt White in Tampa
I kinda got frustrated like you and just had the secondaries removed with a reprogrammed chip
you can just wire them open if you like and remove the vac spider and quite a bit of misery (parts left out don't break)
but trouble shooting the factory stuff isn't too horrible either if you get a hand with it.
if you don't have the Factory Service Manual, it's time. I have one for 50 if you need one.
LOTS of ZR-1 folks in your neck of the woods. Reach out to the zr1 net reg and post up!!
P.S. I am on the ZR-1 Net Reg also with the INDEX called Solutions and I might just send you back here to the Sticky above
TOP END RESTORATIONS SUMMARY
Post 62 - 1990 (#2067) LT5 Top End Rebuild (C5 Z06./Wilwood Brakes, SW Headers, Aluminum Radiator)
Post 76 - 1991 (#1427) LT5 Rebuild (C5 Z06/Wilwood Brakes, SW Headers, Ron Davis Radiator)
Post 119 - 1990 (#3032) LT5 Top End Rebuild (Fluidyne Radiator)
Post 133 - 1990 (#0072) LT5 Top End Rebuild (Ron Davis Radiator)
Post 230 - 1995 (#0186) LT5 Specific Top End Rebuild (C5 Z06/Wilwood Brakes, Fluidyne Radiator)
Post 261 - 90’ (#8550) Corvette (L98) Modifications (SW Headers, Ron Davis Radiator)
The Secondary Operational Test involving grounding the ECM wire will confirm all the mechanical parts are clear and working (not binding on anything). Will also confirm the secondary vacuum solenoid is functioning. The guys that wire the secondaries open have the Plenum off to accomplish that.
I am aware that I would need to remove the plenum to wire open secondary solenoids. I will reread your pages on rebuilding secondaries. My question is why can't one just leave them wired open? It's a closed system so should not be a problem and I would eliminate the need to open the secondaries. Sure you can remove them but why can't I just wire them open and basically it is full power all the time(which I leave it in anyways).
I will find you some posts on wired open secondaries. Among these posts are several ways to wire/remove secondaries
Having an Operational Secondary Full Power Switch TIPS
What Conditions Allow/Cause Secondaries to Open TIPS
Secondary Functional Test and Reconditioning the Secondary Actuators TIPS
Secondary Failure at 5K rpm
Removing Secondary Shafts Engine In Car TIPS
Secondary Canister Installation FACTS TIPS
Removing Secondaries TIPS
Removing Secondary Vacuum System Questions TIPS
Secondary Canister Installation TIPS
Secondary Removal TIPS
Secondary actuator operation VIDEO
Secondary Vacuum Reservoir Source TIPS
Secondary port vacuum diagnosis TIPS
Eliminated Secondary Throttles/shafts Tricks
Secondary vaccum system removal
Secondaries removed picture
Remove secondary throttle plates and shafts
Dorman plug for removed secondary throttle shafts
Secondary failure
Upsidedown Secondaries
Secondary cannister failure
Ebay ZR1 LT5 Secondary
Do NOT give up yet
As it happens, when I first got my 90 ZR-1, it behaved as you describe your aymptoms, including the mileage. Turned out to be that accordion air hose was collapsing. I made an aluminum liner for that hose which solved that issue. But, Marc Haibeck (ZR1 Specialist.con) sells wire hoops to insert inside the hose that also keep it from collapsing.
So, if you verify that the secondaries are opening,. I'd reinforce that air duct hose too, before looking further.
"So, if you verify that the secondaries are opening,. I'd reinforce that air duct hose too, before looking further."
Removed it last week and it made no difference, still falling flat around 5k.
Like this?
feels like rev limiter at 5,000 rpm in 3rd gear
A Vacuum Canister was not holding vacuum in this case.
St. Jude Donor '11, '14
Kurt White has left the country.
By removing the secondaries in an already port and polished engine I would assume the engine will make more power down low where the butterflies were remaining closed and possibly make a little more hp/to
Do to that little better flow and a retune that allows for it?
TIA,
Robin
TIA,
Robin
TIA,
Robin
TIA,
Robin
the gain is a small amount of mid range. to really take advange of this mod the porting needs to be updated to take advantage of the secondary flapper being removed
for SURE you need the updated chip, you can't just wire them open.
Only thing I have noticed with the big LSV engine is that there is more rapid throttle response and of course no annoying air pump (geez these things are LOUD) or snakes nest to befuddle you.
Marc estimated leaving the secondaries in place only costs about 3 cfm, but for sure I recommend removing them and make sure you lock tite the little dorman plugs.
we managed to pop a few out making for a very nasty vacuum leak and another plenum pull.
where this mod can hurt is emissions. at low speeds keeping the secondary closed increases port velocity.
glad you got the beast going! what was it?
you lose a small amount of torq below 2k.
I am in the middle of haveing the body kit installed.then I will get to the engine and then the interior. The kit has been a challenge I am on my second installer and about 8weeks into the installation. Maybe this weekend it will be done.
