Any info on this car - grey 92 in Atlanta
Received 2,275 Likes
C4 of Year Winner (performance mods) 2019
It's a grey metallic, not sure if it's Charcoal Metallic (91 color) or Spiral Grey Metallic (C5 color). Will have a better idea when I see it in person as I had a Spiral Grey C5. It was repainted around 2008/9 as Carfax shows a color change in 09. Original color was black.
The shifter definitely looks a little odd, I'm guessing it's a later model shifter as it looks like stock height without the pull ring. Definitely like you're shifter, that's what I'm looking for.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Check the color code.
I repainted my 93's LT5 while in the car with Jerry's Paint.
http://www.jerrysgaskets.com/paint-l...ish-90-95-6e3/
1991 RPO color codes included both:
25 - Steel Blue Metallc
96 - Charcoal Metallc
http://www.vettefacts.com/C4/1991.aspx
After doing some looking I don't think it's charcoal, but I'm not sure it's Steel Blue either. The lighting in the photos makes it hard to tell. Whatever it is, I love the color. Once I see it in person, I'll have a better idea, and when I get it back I can have my paint shop guy figure out the exact color (so we can do a front plate cover).
Nice, I may end up trying that. Not much too loose if it doesn't clean up well. Worst case it doesn't turn out good and I have to get it professionally refinished (which I've already budgeted for).
St. Jude Donor '16
Once you get it home look at the
St. Jude Donor '16
If its missing or you want, just contact the NCM and order a copy of the window sticker and build sheet all you need is the vin #.
You must have not read through everything, the car has been resprayed.
I've got the RPO list, it was originally black.
1993C4LT1 (12-06-2017)
#38
#39
That 90 on e-bay is down to $8500. Gotta be the cheapest ZR1 out there that runs and not smacked up etc. Your ZR1 is still on e-bay....guess they don't trust your deposit
#40
