Removable top info please
Seems like I remember seeing somewhere that the removable tops (painted & clear) were marked with the vehicle serial number. If this is true, where on the tops would it be?
I've got both tops & have not located one on either.
Of course, I could be remembering wrong on this. Hate those senior moments !!
Does the top appear on the SPID for the car? Is it the correct color to match the SPID? I've got snapshots but not on this PC. Someone will post one I'd think. I will if I'm at that PC later.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
It is only on my Plexiglas top of both the 91 & 93
Thanks Guys.
I will have a look this evening and see what I find. The picture is very helpful We Gone.
The second top shows on both the build sheet and the window sticker. Are one of these what you are referring to as "SPID"?
24S-BLUE
64S-BRONZE
SPID - Service Parts Identification Decal/Details on the console door, you didn't mention year so if '95 would be in a rear compartment.
It is '90 #442. The window sticker indicates blue, which it is. I will check the "SPID" and build sheet just to make sure.
Thanks everybody for the help.
I checked the glass top and found the correct serial number stamped exactly where you indicated it would be.
"SPID" and the other paperwork all lines up correctly as well.
Thanks again guys !!
