Coil on plug LT5
Coil on plug LT5
Looking to install coil on plug on an LT5 engine, searching for a part application that will work on an LT5, even better a part number, I appreciate any info, Thanks, Al
Well keep me posted because I have wanted to do this for some time. In fact I had been able to start and run the motor for about 45sec before the ignition fuse was overpowered by the coils and blew out. Idled nicely.
However, the use of CnP or CoP requires a significant
modification because of the unique LT-5 ignition control module and 9 slot reluctor cast into the LT-5 crank. Use of a different ECM entails isues w CCM comms.
U could take a look at torquehead.com. They have a complete upgrade to CnP for LT1/4 motors eliminating the Opti. And they have comms w the CCM.
U should ping them and let them know of the interest. I have been letting the owner know that there is demand out there. Maybe if enough of us do that he will understand better what I have been telling him.
Thanks, Al
IMO, stock ECM is just fine for LT5. No need for aftermarket units.
Eliminating the ignition module is ok IF u don’t need to communicate w CCM. Otherwise, its an issue.
Torquehead seems to have figured that out using a 24x reluctor wheel and 411 PCM for C4 LT motors. Calibration wise the LT5 is not that much different. I’d rather have OEM equipment anyway.
Dominic, in my 57 i have a crate engine which did not come with an ecm but with the ign module, and we have 2 additional engines and one ecm which I will keep as a spare for my 90, on my 57 the LS coils are mounted under the plenum, and will will be the first one i want convert to cop, i can post a pic but you can't see the coils.
Al,
Could u describe if there is a significant or discernible difference in how the LT5 runs w CnP? If so, how is it different or even better in your opinion?
I would take advantage of shorter cable lengths by putting them through the runners of the plenum.
When I tried CnP, I actually hung them off the plenum. I could see an istallation of the coils on the outsied of the plenum, w each one being close to the corresponding cylinder. Given how much smaller the coils have gotten, They may not get in the way. What would also be interesting is finding COP that actually fits into the spark plug well. I have been told that CnP puts out more energy though.
Al,
I'm excited to hear you are doing a MS3 Very nice system
There quite a few nice features. Raptor did a PNP MS harness but as Dominic mentioned it doesn't take care of interfaces for the mileage and security system.
My holy grail is a TT ZR-1 but I would love to get more info from you as the project progresses.
The stock ignition is good up to at least 700 hp NA and LPE ran it on boosted cars up to 1100 hp so the factory ECM and coils are pretty good stuff.
We're wanting to back fit an LT5 into c3 and the MS3 looks like a great solution.
Are you going to drive all the injectors all the time? On the factory ecm we run em both until under 1% tps and then cutover to 1 injector
WB tuning will be great! and the MS3 pro is getting better all the time.
I happen to have a saturn sky redline and the coil looks like it might work. There was a gent that posted that merc marine had one that fit great, all their new stuff is cop.
A number of us are pushing the AMP guys (MS3Pro) to reopen the ZR-1 ECM project. Dominic has a good dialog going with the right folks at Torqhead, LTD. Seems to me that each of these companies have NRE expense recovery that could be enhanced by adding the LT-5 to their ECM platform. Torqhead appears to have solved the LT-1 / LT-4 CCM and engine management puzzle, but not the LT-5 engine management. AMP looks like the MS3Pro handles the engine management, but no CCM interface. I spoke with the AMP guys at PRI early this month. They indicated they were willing to "dust off" the ZR-1 project if they could get some help with the CCM coms. They further indicated that they had identified 3 potential leads for this at PRI. I passed along the Torqhead website for their perusal. They (Matt) responded immediately and said they would add this to their solution path.
I don't need either of these for my setup, having used TunerPRO RT and Moate's interface along with real time WB data logging to tune my '91. Works perfectly. However, my son and I are seriously looking at using my '91 to create a TT setup. For that, I will definitely want to use OBDII tuning tools (notably HP Tuners). A TT setup may also require an improved clutch setup. My son's TT C-5, running 403 CI is putting over 1,300 hp to the ground and he's pushing the clutch setups available in the C5 (bell housing is shorter than C6, so triple disks are out and modified twin disks are right at the edge when torque approaches 1,300 lbft.)
Just passing along that there are a number of us LT-5 guys pushing the edge to find a possible solution for seriously modified LT-5 platforms..
Steve
https://www.full-race.com/store/borg...fr-7163-turbo/
Tight, all in one package. Will make installations much less involved regarding all relevant piping.. Plenty of space where header collectors are now in my '91. Would build custom exhaust manifolds.. Just food for thought..
Steve, there was previous member, Ron Hanselman, who went down the TT road. Even started a company called Raptor. For some reason, I believe it was tuning, they never finished the project. I believe he is in Texas now, last I heard. He might be a good source for you if you decide the commercialize your TT project. Not sure what Ron is up to these days. A search of previous posts should find a reference. He does check in here and over at ZR1.net from time to time.
H
H
H
H
Here is the old website for Raptor.LLC
http://www.raptorllc.net/LT5.htm
H
