Great price on lower mileage White 91 Z...
I'd buy it...but these cars make me nervous as it seems not many mechanics will touch one. What if the Optispark went bad?
What if you had a spun main bearing?
Are there any mechanics that know how to work on one?
What's this about the Cam Tensioners going bad...Injector's...Al Dunn Heads?
Parts...gaskets...etc??
Thanks!
Thanks!
Thanks!
Thanks!
What if you had a spun main bearing?Extremely rare
Are there any mechanics that know how to work on one?yes
What's this about the Cam Tensioners going bad...Injector's...Al Dunn Heads?Extremely rare regarding Cam Tensioners and Injectors maybe replace if originals and there are a few with double Dunn Heads (I have one 95 with both Dunn Heads)
Parts...gaskets...etc??Jerry's gaskets has everything at very reasonable prices and delivers in two or three days where ever you are
Thanks!
Thanks!
The LT5 is a very reliable engine and lots of fun to work on/modify and just have fun driving the ZR-1 around or cross country.
Thanks!
Thanks!
Thanks!
Thanks!
I’m not one to pile on, but with the possible exception of finding a mechanic your statement could not be more wrong. My Z with 181k miles is a good example. Till now all original and dealer maintained till 2009. Sure it’s had repairs over it’s 27 years and many miles, all in the maintenance category. What cars that have survived that long haven’t?
For your information, ZR-1 don’t have an Optispark system, that’s the LT1
Spun bearings are exceptionally rare and are available if they do.
Chain tensioners do not go bad. The ones on 90’s have an inconsequential rattle at cold start.
Injectors do go bad, particularly on 90’s, however replacements can be found at any auto supply. What 27yr old cars don’t have injector issues?
Dunn heads were simply a supplier change by the factory and possibly an improvement on some of the 95 models, if anything they flow marginally better than the previous supplier heads.
Parts and gaskets are supported by several suppliers specifically for the LT5. As noted Jerry’s Gaskets and Mark Haibeck are primary suppliers.
Most of all the national support community for the ZR-1 and its Owners is like nothing you have ever seen. There is literally nothing, no technical data, no spec, no repair procedures, no parts source that is not happily shared.
As you have observed people get touchy when these common misconceptions are thrown around. As was pointed out it is these attitudes (in our opinions) that keep the ZR-1 from becoming the the classic we feel it should be.
I see your in Vacaville. I’m in Reno. There is a small group here and in the Sacramento/Bay Area. Some of us plan to get together this spring in the Sacramento area. I invite you to join us and learn more about these unique cars.
H
Thanks!
Thanks!
do some research... I spent hours reading about these things before I bought mine. I have total confidence in the LT5 and the ZR-1 community
These motors are beyond the traditional concept of durable. They take the gold standard expectations we have of the traditional SBC and raise the bar. If the rest of the car checks out, this is a killer deal. The engine appearance-wise is gorgeous.
Well, seeing as how you owned #1673 for 5 years, me for 6, and blackbelt for another year now, and that the engine has never been cracked open for anything except gaskets...????
but, to answer the OP's question...C4's will nickel and dime you to death if you aren't doing 2/3rds of the wrenching yourself. I got tired of it after awhile...I mean the car was almost perfect afterwords...I guess I finished and wanted a new project.
The other reason was the car ran sooo much better with headers, but I didn't need to deal with the smog in my zip.
