Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C4 Corvettes, 1984 - 1996 > C4 ZR-1 Discussion
Reload this Page >
Considering buying a C4 ZR1 - Question on Painted Engine
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Old 03-03-2018, 03:08 PM
56v225
CF Member
Default Considering buying a C4 ZR1 - Question on Painted Engine
Am considering purchasing a C4 ZR1, but am totally new to C4's.
While looking at possible candidates, have noticed that some have
painted/powdercoated the engine to match the car's exterior color. How
difficult would it be to either replace or restore those painted/powder coated parts to original, and what would be a reasonable cost estimate.
Thanks for any help or comments.
56v225
56 225hp
67 L79 350hp Conv
56v225 is offline
Old 03-03-2018, 04:21 PM
Evan70
CF Senior Member
Evan70's Avatar
The OEM finish on the LT5 does not hold up well, so there’s 3 options you’re going to find:
1. The OEM finish hasn’t been maintained and looks like crap.
2. The engine has been refinished, which can cost a couple grand and will hold up much better than stock.
3. Someone has taken great care of the original finish, which is fairly rare.
You can’t make it look “original” if it’s been refinished, but you can get close. Check the ZR1 dot net forum and ZR1Specialist for more info.
Evan70 is offline
The Following User Says Thank You to Evan70 For This Useful Post:
56v225 (03-03-2018)
Old 03-03-2018, 05:35 PM
Paul Workman
CF Senior Member
Paul Workman's Avatar
Jerry's Gaskets sells the original paint for restoration projects.
If you don't like color, It is no big deal removing the plenum and cam covers and injector housings and refinishing them.
Marc Haibeck can refinish them for you, if you don't want to try it yourself.
Nothing like a fresh coat of paint to freshen up the look of the LT5!
Paul Workman is offline
The Following User Says Thank You to Paul Workman For This Useful Post:
56v225 (03-03-2018)
Old 03-03-2018, 06:27 PM
56v225
CF Member
Thanks for the quick responses....sounds like a reasonable fix.
Thanks again
Dan
56v225 is offline
Old 03-03-2018, 10:07 PM
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Location: Fremont Ca. I will do No business with ANY company that boycotts Arizona.
It does not cost a couple grand to have these parts refinished,with all of the current options for a PC finish I would venture to say it is 100% possible to match the OEM look. I’ve seen the stock finish in several different shades of silver and even over time turn an almost solid grey. The only issue I have with sending out these parts to have to have them PC’d is something happening to the cam covers,the cam covers are a matched set to the heads to nothing can happen to the cam covers. Now getting the cam covers off is a job all it’s own animal. As mentioned the OEM finish is pretty fragile as far as cars goes,it’s very easy to stain the finish when getting anything on it. How I care for mine is I’ll wipe it down with the motor stone cold with diluted Windex and then go over it with a damp towel. Cars only got 24,000 miles but it is 27 years old. With all the Zs on the market with cash in hand if I were in the market I might pass on a car that had a less than satisfactory finish on the motor. When the time comes I’m not sure what I’ll do when it comes to a refinish as the original finish on mine still looks pretty good. The nicest I’ve seen yet was a silver with very fine metallic in high gloss clear coat. There was a member years ago that had a yellow 94 and the finish on the motor in that car looked like just gorgeous.
Z51JEFF is online now
The Following User Says Thank You to Z51JEFF For This Useful Post:
MightyZR1 (08-05-2018)
Old 03-03-2018, 11:06 PM
JShort
CF Senior Member
Originally Posted by Z51JEFF View Post
the nicest Iíve seen yet was a silver with very fine metallic in high gloss.
Jeff,
I agree! Thatís the exact aesthetic (powdercoat) on my engine:
JShort is offline
Old 03-04-2018, 07:18 AM
FASTAZU
CF Senior Member
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Repainted with paint from Jerry's, while in car!
FASTAZU is offline
Old 03-04-2018, 12:22 PM
bb62
CF Senior Member
bb62's Avatar
While the repainted engines show in this thread look fabulous, they do not have that gritty look of an original. While that may only be important to investors and NCRS types - it is a different finish.
bb62 is offline
Old 03-04-2018, 12:57 PM
Dominic Sorresso
CF Senior Member
Dominic Sorresso's Avatar
I always found that the original finish was that more of an industrial motor as compared w that of a finely tuned sport vehicle, ie Ferrari 458.
Dominic Sorresso is offline
Old 03-04-2018, 02:50 PM
56v225
CF Member
Thanks to all for submitting the engine photos that helps considerably.
56v225 is offline
Old 03-04-2018, 06:37 PM
FASTAZU
CF Senior Member
FASTAZU's Avatar
St. Jude Donor '16
Original Paint on my 91, was later redone to fine silver by Marc H.
Fine Silver
FASTAZU is offline
Old 03-05-2018, 11:09 AM
ZR1Bob
CF Senior Member
ZR1Bob's Avatar
I also had Marc Haibeck do mine in fine silver with black and reused original bolts (Marc has a good supply of takeoff bolts if yours are a bit rusty). I wanted it to look as close to stock as possible and I was happy with the results. The "Haibeck 350 510 HP" letters are decals and can be removed or not installed in the first place). But I admit I had mine done when Marc did the 510 package. That's what you really want to do; the refinishing is just the icing on the cake. And I don't think NCRS docks you much for a refinish since the original finish as noted does not hold up well.--Bob
ZR1Bob is offline
Old 03-06-2018, 03:28 PM
DRM500RUBYZR-1
CF Senior Member
Support Corvetteforum!
DRM500RUBYZR-1's Avatar
If you think they look good,
You should hear them as they sing going from 3,000 rpm to 7,000!
Then you will surely have witnessed their "shine"
Marty
DRM500RUBYZR-1 is offline
Old 03-09-2018, 07:53 PM
Jagdpanzer
CF Senior Member
Jagdpanzer's Avatar
My 94 Z motor in silver PC
Jagdpanzer is offline
Old 03-11-2018, 07:11 PM
Not Red Rob
CF Senior Member
Not Red Rob's Avatar
I had Marc Haibeck do mine in bright red, it’s like candy!!
He also did the 510 HP package along with Corsa’s and 4.10 gears, amazing!!
Not Red Rob is offline
Old 03-14-2018, 10:43 AM
rudolph schenker
CF Senior Member
rudolph schenker's Avatar
Mine.......done by Marc Haibeck
rudolph schenker is offline
Quick Reply: Considering buying a C4 ZR1 - Question on Painted Engine
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
