Radio no sound - 1990 ZR1 (Bose)
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Here are some trouble shooting tips, I have also had t CDM's repaired by them they can also add an I-Pod hook up.
Very happy with the results.
http://carstereohelp.com/corvette.htm
1971 Judge (05-12-2018)
Thanks for the information. I just got the 8A factory manual, which shows a relay between the radio box and the amplifiers (all make a little noise). Anyone had this relay as the problem? I hope to test it this weekend.
Zen Vet Master Level VII
Your bet is the EDM has failed. This is an all too common occurrence.
If your whole system is out, then the EDM is shot. If you had only a couple of speakers working then I'd say that your speaker amp were the problem.
Sorry, it is a PITA to fix. I did it in 4 hours.
H
