C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Zr1 ‘secondaries’ are these extra fuel injectors?
Old 09-22-2018, 03:14 PM
dizwiz24
dizwiz24's Avatar
Default Zr1 ‘secondaries’ are these extra fuel injectors?
What are ‘secondaries’? Are these an extra set of fuel injectors?
Old 09-22-2018, 07:04 PM
EvanZR1
EvanZR1's Avatar
Received 2,243 Likes on 1,178 Posts
C4 of Year Winner (performance mods) 2019
The LT5 has two sets of intake ports, with the "secondary" set having a second set of fuel injectors and a second set of "throttle body" blades. In stock form, this is controlled by the "power" key on the dash, when turned to full power, the system is active and controlled by a vacuum system. That vacuum system can easily fail, leading to the "secondaries" not working. Many people have the system set to run full power all the time with a custom chip, and if you want you can even remove (or tie open) the secondary blades so you no longer have to worry about the system failing.
Pic of the secondary port (one with the blade) next to the primary port:
1993C4LT1 (09-22-2018)
Old 09-22-2018, 09:05 PM
dizwiz24
dizwiz24's Avatar
Cool ! Thank you!
Never knew it was more than just 8 more fuel injectors !
so there are 8 more throttle blades as part of the secondaries ?
Old 09-22-2018, 10:09 PM
EvanZR1
EvanZR1's Avatar
Yes, 8 extra injectors (16 total), and yes the secondaries have throttle blades that only open in certain situations, basically heavy throttle and/or high rpm. Under light throttle the blades stay closed and the secondary injectors are off, giving better MPG.
Old 09-23-2018, 10:44 AM
Paul Workman
Paul Workman's Avatar
Ummm... I'll might take exception to the "better MPG (w/ secondaries OFF) statement", practically speaking. Oh, yes, there is technically a slight % higher torque w/ secondaries OFF, primarily in the low-mid rpm range. But, only with light throttle. With any hilly terrain, the secondaries are often opened at highway speeds.
One area that might favor the primaries ONLY running is emissions compliance. But, even that said, compliance is common with the secondary port throttles REMOVED as well. Just sayin.
(BTW, where did all the metal filings, etc., come from in that picture???)
Old 09-23-2018, 03:40 PM
EvanZR1
EvanZR1's Avatar
I actually was being a little sarcastic on the MPG statement, as in the MPG would be better with them off AND power key off versus full power mode.
pic was during tear down by Pete to do my 391 build.
To Zr1 ‘secondaries’ are these extra fuel injectors?
Quick Reply: Zr1 ‘secondaries’ are these extra fuel injectors?
