LT5 in 90 ZR1 running rich
Cruising
90 ZR1 running rich, fouling plugs on passenger side then oxygen sensors - worse on passenger side. heavy carbon fouling. Possible causes?
1. Remove vacuum line from Fuel Pressure Regulator. Key on. Any fuel coming from vacuum nipple on Regulator?
2. Are all 4 plugs on passenger side fouled? If not, which ones are fouled?
3. Are plugs oily?
4. Are the stock exhaust manifolds & cats still in place?
3. Are plugs oily?
Zen Vet Master Level VII
Am I close?
Jerry is the authority but let me make a guess-- and it IS a guess. If your FPR was faulty (ripped membrane) raw, un regulated (or at least less regulated) fuel would get dumped into the system. The first (or actually top) feeder hose for the fuel rails feeds the right side. Hence any fault in the FPR would show up on the right side of the engine as extra fuel dump.
Am I close?
Am I close?
3. Are plugs oily?
A bad O2 sensor may be at fault, but without the means to test it and no DTC codes given, it's hard to consider it as being the primary source. Insofar as the problem being injector related, it would be unlikely that all bad injectors are on the right bank only. As such, the simple, no cost checks offered can help with the diagnosis.
