ZR-1 rear gear change
Has anyone here changed over to a 4 series rear end from the stock 3.45:1? If so, how did you like it? I'm contemplating a switch to a 4.11 in my '93 this spring to at least give it a little help keeping up with my '72 540 CID big block. With a torque peak at 5200 RPM, I always felt the '93 needed more gear.
Best wishes,
Larry
Best wishes,
Larry
Received 2,275 Likes
C4 of Year Winner (performance mods) 2019
Had 4.11s in my previous 91 with just ported intake and long tubes. Made the car very responsive, and what I felt like it should have had from the factory. For my current 91 with 391 cubic inch, fully ported and long tubes, I kept the stock gears, which was the right decision as I have a hard enough time putting the power down in 1st as is, 4.11s would have made 1st useless.
Did the 4.10 gears in both my '93 and '95. Best mod you can do for the money. Marc and Bob Haibeck have done many of these and Marc has considerable info on his website. Here is a link to his comments on the gears: http://www.zr1specialist.com/HAT%20W...ucts/gears.htm. Depends on what you hope to gain from the change. It significantly improves around town driving and sixth gear becomes much more useful. On the drag strip, while you can get to the end of the quarter mile in third gear with stock 3.45 gears, you have to shift to fourth with the 4.10s. But I drove my cars daily in the summer and only drag raced once or twice,so I was a happy camper. I also did a couple other simple mods that really improved the feel of the cars, including a Hurst short throw shifter with a stock looking gear lever and Hawk brake pads. After that, well, there is always Marc's 510 HP package that I did on the '95. That perked it up a bit....Bob
Received 1,869 Likes
I went with 4.30 cogs, in my 90 Z. My 91 Callaway Z had the older 4.09 gearset, while my 94 Z had 4.10's.
My favorite gear was the 4.30.
Thanks to both Evan70 and ZR1Bob! I know quite well that even the 4.10's won't be anywhere enough to let the former "King of the Hill" keep up with my '72 with the 540, but have felt for quite awhile that the old "King" deserves a better chance to keep up with current "traffic."
Thanks so much, guys,
Larry
Larry
I loved the 4.10's in my first 91. But it also had headers, no cats, and the early 3" B&B exhaust along with a custom chip. The extra gear helped it a lot. I'm thinking about having my current car which has more hp changed to the 4.10's. One thing is for sure. It wouldn't hurt if you made the change. Just your wallet.
Thanks to all that responded. So very nice to have all this experience at one's fingertips! Some of the other mods mentioned will be given full consideration as well--great forum!
Sincerely,
Larry
Sincerely,
Larry
4.30 gears for sure! That's what I had on my Z and I believe I was one of the only members to pop a "baby wheelie" at the race track. I even had the stock heavy wheels on the front! The only other mods were headers and Corey Henderson tune. She made 432 rwhp. Take a look:
Yeah, but didn't you break a half-shaft doing that?
LOL! I snapped the halfshafts on the last run of the evening. My 4000 rpm launch was too aggressive. But the shafts should hold up fine on normal drives or even launches in the 2K range. If I remember correctly, i took her to the 1/4 mile track one and she ran a 12.20 @ 115 mph. Not bad for a mostly stock Z!
Thanks to both Dominic and Nacho ZR1--more to consider! By the way, my '72 with the 540 makes about 640 (gross) hp, dead-hooks with 16 psi in the Mickey Thompson 275R 60/15 drag radials, and I haven't broken anything yet. I did have to have the tires pinned to the wheels recently, though, as it was turning the tires on the wheels and losing air pressure with every such launch, so we'll see what happens when that slippage is no longer there to absorb the torque!
Highest regards,
Larry
Highest regards,
Larry
