C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Forgelines and Carbon ZR-1 brakes
Old 01-29-2019, 06:39 PM
1LEZ
1LEZ's Avatar
Spot on
Old 01-29-2019, 06:40 PM
1LEZ
1LEZ's Avatar
Originally Posted by USAZR1
Due to the size of those calipers and the wheel offset required to fit over them, there's not enough room for much more than a 1" lip on the front wheels.
Spot on
Old 01-30-2019, 06:20 PM
JimZRyd
Support Corvetteforum!
JimZRyd's Avatar
St. Jude Donor '12
Originally Posted by 1LEZ
Yes Center loc
👍🏻Sweet
Old 01-31-2019, 10:23 PM
Z51JEFF
Z51JEFF's Avatar
Car is gorgeous.
Old 02-03-2019, 09:42 AM
henryr
henryr's Avatar
i would love to do that brake swap but its looking like the whole deal would cost as much as my car....
henryr
henryr's Avatar
what is the difference in sizing between the c6 zr1 brake setup and the z06 ?
Old 02-03-2019, 11:02 PM
USAZR1
USAZR1's Avatar
Received 1,870 Likes on 1,085 Posts
C6 Z06 brake rotors are 14" front and 13.4" rear. The carbon C6 ZR1 rotors are 15.5" front and 15" rear.
Not a bad price on these used fronts. https://www.corvetteforum.com/forums...nd-rotors.html
Old 02-08-2019, 07:18 AM
RapidC84B
RapidC84B's Avatar
Received 13,165 Likes on 5,989 Posts
Amazing... well done. Were you at Carlisle last year before these latest mods? I feel like I saw your car.
Old 02-08-2019, 10:25 PM
1LEZ
1LEZ's Avatar
That is correct. Still had the other brakes and tires on at the time. Started this project when I got home from PA
Old 02-09-2019, 09:33 PM
Eric Reeves
Eric Reeves's Avatar
Awesome job. I recall Pumba doing this several years ago with a C5Z and doing a big write up about it. If I recall he is/was an engineer with GM or had someone with him that was. What I remember the most was that he had to redo all the suspension because the knuckles were not strong enough to handle the loads the brakes could exert on them. Not saying you will have an issue but its worth a search over in the C5 part for it.
Old 02-10-2019, 12:32 AM
RapidC84B
RapidC84B's Avatar
False... we race C5s on stock uprights on slicks no issues. Punbas car was very nicely done, but he didn’t change uprights due to brake torque.
Old 02-11-2019, 07:32 AM
Eric Reeves
Here is what he did and why. https://www.corvetteforum.com/forums...s-inquiry.html
Old 02-11-2019, 09:08 AM
  #33
RapidC84B
RapidC84B's Avatar
Yes... he put the latest iteration of uprights on because the caliper mount is way beefier from GM's testing at the Nurburgring. I ran them on my C5 racecar as well. It has nothing to do with braking force generated by the carbon brakes, but with upright flex under hard cornering pushing caliper pistons away from the rotor creating an initially soft pedal.
Old 02-11-2019, 05:23 PM
  #34
Eric Reeves
Like I said I was going off memory from 2011. Therefore I found the link and posted. Thanks for the clarification.
Old 02-16-2019, 07:50 PM
  #35
1LEZ
1LEZ's Avatar
Default Pumba
Pumba and I emailed back and forth a few times. My car is more about the show and rarity than race track performance. I do drive my car but I don't want to subject the paint to hard track days. Thanks for the input!
Old 02-17-2019, 09:42 PM
  #36
Anthony F
Anthony F's Avatar
Wow, that is was gorgeous ZR-1 you have there.
Old 02-23-2019, 06:49 PM
  #37
henryr
henryr's Avatar
the j55s are 13" ... do the C6 Z06 brakes fit under the 17 " A molds ?
To Forgelines and Carbon ZR-1 brakes
Old 02-24-2019, 12:32 AM
  #38
Dominic Sorresso
Dominic Sorresso's Avatar
No u need 18” wheels.
henryr (02-25-2019)
Old 02-27-2019, 09:36 AM
  #39
henryr
henryr's Avatar
so if i am googling correctly....
the zr1 CF brake rotors should fit over 18" wheels assuming offsets are correct ?
i found a set of 18"/19" wheels i think they call the Cup versions of an anniversary 427
Old 03-03-2019, 06:51 AM
  #40
Verrückt ZR1
Verrückt ZR1's Avatar
Cup wheels were exclusively 19"/20", so you may be looking at replicas. C6 ZR1 rotors typically need 19" wheels up front to clear, though there are a couple of 18's that will fit.
henryr (03-03-2019)
Quick Reply: Forgelines and Carbon ZR-1 brakes
