C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
19" cup wheels on a c4zr1...
Old 03-17-2019, 09:39 PM
henryr
CF Senior Member
henryr's Avatar
Recieved 3 Likes on 3 Posts
Default 19" cup wheels on a c4zr1...
going thru some options
i've run the comparisons on a wheel / offset site. these look like they should fit :
factory 19x10 40 offset on the front 275/30/19
repro 19x12 59 offset on the rear with a spacer. ..... 333/25/19
the rear is going to need a spacer and unsure which size to use and the tire sizes
any thoughts ?
i thought there was a posting by another user that mounted a set of the new zr1 repros on but search doesnt pull up anything for me
henryr is offline
Old 03-18-2019, 03:07 PM
USAZR1
CF Senior Member
USAZR1's Avatar
Recieved 101 Likes on 82 Posts
A 19x12 w/+59 offset has 8.80" backspacing. Max rear backspacing on a C4 ZR-1 is right at 8.40" so you will need a 10mm or .400 spacer. Might be easier to find a 1/2" thick hubcentric adapter/spacer. http://www.motorsport-tech.com/
Should be able to fit a 325, 335, or maybe even a 345.
IIRC, the 19x10 CCW fronts on my 94 had +48 offset, maybe 50. The oem 9.5's have +56. Not sure if a +40 offset will fit correctly, on the front.
USAZR1 is offline
Old 03-18-2019, 07:01 PM
henryr
CF Senior Member
henryr's Avatar
thx...
i am going to see if i can borrow a front for a test fit
henryr is offline
Old 03-18-2019, 09:34 PM
Not Red Rob
CF Senior Member
Support Corvetteforum!
Not Red Rob's Avatar
Recieved 136 Likes on 105 Posts
Iím Running C6 Z06 Spyders in stock sizes 18x9.5 & 19x12 I used a 3/4Ē hub centric spacer on the rear with 345/30/19 Nitto NT05 Drag radials. They fit perfectly, and completely fill up the wheel wells.
I donít have a good picture, here are the one I have hope it helps, first pics is after coil-overs last pic shows the new rubber before it went on.
Not Red Rob is offline
Old 03-19-2019, 03:47 PM
henryr
CF Senior Member
henryr's Avatar
thanks
are you using the c6 z06 brakes up front ?
anyone know of the zr1 calipers will work with the smaller z06 rotors ?
henryr is offline
Old 03-19-2019, 04:15 PM
Not Red Rob
CF Senior Member
Originally Posted by henryr View Post
thanks
Yes I have C6Z06 front and rear calipers and rotors.
Old 03-19-2019, 04:29 PM
henryr
CF Senior Member
henryr's Avatar
thx
can you post up some more pics when you get a chance ?
henryr is offline
Old 03-19-2019, 07:50 PM
henryr
CF Senior Member
henryr's Avatar
google says no on the zr1 calipers and z06 rotors... just fyi
henryr is offline
Old 03-20-2019, 10:05 PM
Not Red Rob
CF Senior Member
Please excuse how dirty the car is, we are starting to disassemble to restore and change colors, itís going to be Matte Admiral Blue with Red/Black Grandsport themed interior.
Flush with rear quarters
Rear Wheel
Flush with front fenders
Front Wheel
Side shot
chgc267 (03-20-2019)
Old 03-20-2019, 11:13 PM
chgc267
CF Senior Member
chgc267's Avatar
Recieved 35 Likes on 23 Posts
Rob, Thanks for posting those pictures. I already have the C6ZO6 calipers and have been contemplating the Cup wheels or the Spyders on my Z as well. I really like the look of the Spyders! Are those OEM wheels or reproduction? Also, what size tires are you running up front? Can you comment on the handling / braking w/ that set up too?
chgc267 is offline
Old 03-20-2019, 11:30 PM
Not Red Rob
CF Senior Member
Front tires are 275/35/18, Iím not sure if the wheels are OEM, I bought these years ago on the forum, to use as rollers for my 58 TT Restomod with C6Z06 brakes. I changed wheels and tires first then brakes, the tires are amazing when its warm, a little scary in the rain. The brakes were are a huge upgrade over the stock setup.
Old 03-21-2019, 11:34 AM
henryr
CF Senior Member
henryr's Avatar
rob - can you confirm the factory offsets on those when u get a chance ? looks like there are a couple different aftermarket version offered on fleabay
there is also a vendor on ebay selling the "new" zr1 replicas... in the description it says can do different offsets
henryr is offline
Old 03-21-2019, 11:38 AM
Not Red Rob
CF Senior Member
I'll try to pull them and check the offsets, I was told by the seller they were factory offset C6Z06 but I have not confirmed.
Old 03-21-2019, 11:58 AM
henryr
CF Senior Member
henryr's Avatar
henryr is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
