C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
cam timing seminar /dyno day
Old 05-29-2019, 12:27 PM
spork2367
spork2367's Avatar
I would love to come down and watch the cam timing be done.
Old 05-29-2019, 12:47 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Originally Posted by DDSLT5
are you not running a 160F stat? If not, why not? My 415 routinely operates at 168F, no matter what the temps are outside. It makes HUGE power at this temp. You`re likely thinking - BUT WHAT ABOUT THE GM ENGINEERS??????
I've actually seen it posted, with regard to operating temps that:
*you'll make less power at a cooler operating temp
*You'll wear out your engine
*You fill your crank case with water
*....among other made-up concerns.
Each of those points, plus more, were all addressed in THIS THREAD that is a great read, with videos, pics and hard data from read dyno tests.
Old 05-29-2019, 02:06 PM
Rkreigh
Rkreigh's Avatar
Based on quite a few back to back dyno pulls I've found the car makes best power in the 165-175 range with oil temps up around 200
Emissions likes warmer operating temps, I don't think all of the above fits based on my experiences.
not driving the car is worse than running it at 175
Old 09-03-2019, 04:12 PM
spork2367
spork2367's Avatar
Did you end up getting this back together with the cams degreed?
Old 09-13-2019, 09:40 AM
Rkreigh
Rkreigh's Avatar
not yet, just got some low mileage cam cahins, heads are on, and finally got a durn job so I can pay for it!!
Quick Reply: cam timing seminar /dyno day
