Looking for Hawk brake pads
Anyone know where we can get these for our cars? I would prefer to get some feedback here before just purchasing at a speed shot who claims they will fit. I am going to be doing a HPDE event at the NCM track next month. They recommended Hawk HPS.
Thanks!
Thanks!
Received 1,867 Likes
KNS Brakes is a forum sponsor on this site. Good people to deal with. https://knsbrakes.com/c/car-items/14...uty+Suspension
I love the HAWK HSP pads for general and some spirited driving use - have used them for both at the RM runs in the Appalachian Mts AND the Rock Mt Run last summer - (think high speed "TAIL OF THE DRAGON"!). The HSPs were great! I like "twisty" driving, and the Hawk HSPs have proven to be good beyond the normal street pad application, for sure.
But, HPDE track racing is another level above. For that perhaps the KNS or the like is the answer (but I can't speak from personal experience - far as the KNS pads go...). One thing great about the ZR-1s is the ease at which the pads can be swapped, i.e., after a track event, (racing pads) switching back to "normal" driving pads I find is pretty simple.
Thanks for the input. I will contact you and get some pads for the event. I also would like pads for my 700 Hp C3. I have Wilwood calipers but they accept standard center pin pads. I need lots more grab. I am using the pads that came with the kit and I honestly don’t think there is enough grab to lock the tires up.
Supporting Vendor
Ken
also they recommended pentosin super DOT 4 fluid. I picked some up but realized it was the LV type (low viscosity). Has the same specs as the super but suited more for cold weather applications. Not sure I I should use this. Planning on doing a 4 corner gravity bleed to replace old fluid.
I've been using Hawk HP+ pads for autocrossing for the past 15+ years and absolutely love them on the track. For the street, the first stop takes a little more pedal pressure but after that, they're great. Going from the stock pads to the HP+ pads was like going from manual brakes to power brakes. The brake feel is very linear and it's very easy to modulate braking force. They do squeal a little at times on the street but it doesn't bother me. They also create a lot of dust (especially on track day) and they eat the rotors, but not too bad as I still have the original rotors on my '93 ZR-1. Definitely go to the best brake fluid you can get, DOT 4 isn't going to be good enough. These pads can create and stand a lot of heat, you'll need brake fluid that can keep up with them. To give you an idea of how high the temps get in that area, the rubber on my caliper dust boots melted.
There may be better pads out there but I'm very happy with the HP+.
Ken-is there a special way I need to bed these brakes? I usually scuff the rotors with 400 grit sand paper and run a series of drive and stop cycles at various speeds.
Thanks!!
