C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
ZR-1 1990 sylinder.
Old 05-03-2019, 03:21 PM
Jan Pettersen
Junior Member
Default ZR-1 1990 sylinder.
[font][font]Har problemer med at 1 eller 2 sylindere kutter når bilen blir varm.Når jeg tar av batt. Polen når den er kald så går den på alle til bilen blir varm igjen. Er det noen som har noen tips her takker på forhånd[/font][/font]
Jan Pettersen is offline
Old 05-03-2019, 09:33 PM
ccmano
CF Senior Member
ccmano's Avatar
This translation is close...
Have trouble with 1 or 2 cylinders cutting when the car gets hot. When I take off the bat. Poland when it is cold it goes on all until the car gets hot again. Does anyone have any tips here thank you in advance”
I assume we’re talking about a ZR-1 here. It would help if we knew what year car and how many miles on it. Most likely issues are injectors, especially if it’s a 90-92 with original injectors still in place, ignition coils or fuel pumps. With out more info it’s difficult to assess.
H
ccmano is offline
Old 05-04-2019, 03:09 AM
Jan Pettersen
Junior Member
[font][font]Hei takk for svar.[/font][/font]
[font][font]Dette er er en 1990 mod ZR-1[/font][/font]
Old 05-04-2019, 03:12 AM
Jan Pettersen
Junior Member
[font][font]Denne bilen har gått 110 000 KM[/font][/font]
Old 05-04-2019, 03:51 AM
Jan Pettersen
Junior Member
[font][font]Vis det viser seg og være en injektor er det lurt og bytte alle eller er det bare tull?[/font][/font]
Old 05-04-2019, 11:02 AM
ccmano
CF Senior Member
ccmano's Avatar
So it’s a 90’ ZR-1 with 110,000 km and you think it’s the Injectors. That would make sense. If the injectors are original to the car then all of them must be replaced. With that age and mileage I would replace the coils and wires while your under the plenum, assuming they are original as well. These are what you need.
https://fuelinjectorconnection.com/c...ctor-set-90-92
FIC also sells rebuilt injectors that are about half the price of new.
H
ccmano is offline
Quick Reply: ZR-1 1990 sylinder.
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
