C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
92 ZR1 stalls out
Old 05-30-2019, 05:09 PM
Michael 59' corvette
CF Member
Default 92 ZR1 stalls out
Hi ZR1 owners, I had my 92 ZR1 Detailed Saturday. When I picked it up it ran rough I thought the engine got wet. It was very very low on fuel, so I drove 1 block to a gas station & filled it up when I opened the fuel door it was full of water ( drain hole was clogged) I don't know how much water got in tank but it has rained a lot lately . I drove from the gas station about 1/4 mile & the engine stalled & would only restart for a few seconds. Towed it back to my shop.
First, I put 4 bottles of dry gas in the tank, it ran for about 5 minutes stalled & would only re-start for a few seconds.
Second, changed the fuel filter (same problem)
Third , replaced the fuel relay ( same problem)
Fourth , replaced both fuel pumps & filters in tank (same problem)
I thought it was a fuel problem but ???
Any ideas
Michael
Michael 59' corvette is offline
Old 05-30-2019, 06:41 PM
81c3
CF Senior Member
81c3's Avatar
Did they wet the engine by chance? Could be there is a pool of water under the plenum in the V
81c3 is offline
Old 05-31-2019, 08:41 AM
CF Member
Thanks 81c3,
I am not sure if they wet the engine. Would that make it stall? Someone suggested a crank sensor.
Michael
Old 05-31-2019, 09:31 AM
Paul Workman
CF Senior Member
Paul Workman's Avatar
I'd want to "clear the decks" first: start with a clean sheet before changing out anymore parts, I'd want to scan (OBD-1) the ECM for clues (or use in the FSM and a paperclip, probe for codes).
Far as possible water getting into the tank, it is easy to see inside of the C4 tank when the pump assembly is removed. You can shine a light in there and actually SEE if there's some water globules in the bottom...unless you have gallons of water in there (but if you had, it wouldn't likely have run at all). NOTE: You could siphon liquid from the bottom of the tank into a glass container for inspection. If there's water in there, you can siphon liquid from the bottom until you get all traces of water out of the tank. And, then you can flush the fuel lines and injector rails.)
Let's see what the scanner says or see what codes have been set before proceeding.
Paul Workman is offline
Old 05-31-2019, 10:28 AM
CF Member
Our scan tool only goes back to 1996
Old 05-31-2019, 10:58 AM
ccmano
CF Senior Member
ccmano's Avatar
Check both the MAP sensor vacuum lines particularly the one at the back of the plenum. Generally if water gets into the valley there’s a starting issue not a running issue. Water getting in the ECM is possible tho. You can get the codes using a paper clip at the OBD1 connector under the dash.
http://www.zr1specialist.com/HAT%20W...0Info/aldl.htm
H
ccmano is offline
Mint 66 (05-31-2019)
Old 05-31-2019, 01:52 PM
1985 Corvette
CF Senior Member
1985 Corvette's Avatar
Another vote for checking the MAP vacuum line at back of the plenum. I had the same issue driving when I first got mine. Car would stall when getting off the gas to brake for a red light or to slow down to make a turn. Someone had gotten rid of the original line and replaced it with a thin wall rubber hose that was softened from being soaked in oil. It easily collapsed when I pinched it.
1985 Corvette is offline
Old 05-31-2019, 03:10 PM
CF Member
Just scan it Code 54 came up , low fuel voltage . What dose that mean.
Old 05-31-2019, 05:39 PM
Aaron71771
CF Senior Member
Aaron71771's Avatar
Did you check both fuel pump fuses and verify fuel pressure?
Aaron71771 is offline
Old 05-31-2019, 10:03 PM
Aaron71771
CF Senior Member
Aaron71771's Avatar
Perhaps these will help:
Old 06-01-2019, 12:01 PM
ccmano
CF Senior Member
ccmano's Avatar
I’m betting you have bad fuel pumps. Easy to check.
Fuel pressure should be ~48-55 psi.
With the car cold, hook up a pressure gauge then simply turn on the ignition, don’t start the car. You should see 48-55 psi with the vacuum hose to the regulator disconnected. Then do this test is to check the amp draw of the pumps. Good pumps draw 4-5 amps each, 8-10 amps when both pumps run. Less and your pumps are going bad. It’s nicely written up by Paul here...at post #7.
http://www.zr1.net/forum/showthread.php?p=136108
8amps is minimum for both pumps. Now pull the FP1 fuse (in the fuel box) and test it again. It will give you the draw on the secondary pump, FP2. Subtract that from the first reading you got and you have the reading for the primary pump FP1.
H
ccmano is offline
Old 06-03-2019, 01:27 PM
CF Member
HI CCMANO, I changed both fuel pumps, filters & 3 fuse relays. I got my hands on a old scan tool & code "54 fuel pump voltage is low" pops up any ideas?
Thank You
Michael
Old 06-03-2019, 11:08 PM
ccmano
CF Senior Member
ccmano's Avatar
Start by disconnecting power to the ECM, either at the in-line connector under the ecm, or simply undo the battery positive cable for at least 10 seconds. This will clear the codes. Once reconnected see if the code comes back. If it comes back, you will need to follow the diagnostic procedures above. The next most likely culprit is the fuel pump relay or an intermittent fuel pump ground.
H
ccmano is offline
Old 06-04-2019, 11:10 AM
CF Member
CCMANO, I changed all 3 fuel pump relays last week. Do you know where the intermittent fuel pump ground is?
Michael
Old 06-04-2019, 04:59 PM
ccmano
CF Senior Member
ccmano's Avatar
Did the code come back after you disconnected the ECM? Looks like you will probably have to follow the diagnostic tree posted above to find the fault. While the fuel pump ground is on the inside of the halo near the upper seat belt mount that doesn’t mean the fault is necessarily there. It could be in the wiring or connectors between there and the pumps. Sometimes it’s a wiring or connector issue not a component issue. I suggest you take it to and automotive wiring specialist if your not comfortable tracking wiring faults.
H
ccmano is offline
Michael 59' corvette (06-11-2019)
Old 06-10-2019, 01:53 PM
CF Member
Problem solved , I had a mobile auto tech check out my ZR1. In 15 min. he found a 10 amp blown fuse for the primary fuel pump.
Thanks All
Michael
Old 06-10-2019, 04:51 PM
81c3
CF Senior Member
81c3's Avatar
Question is, why did the fuse blow in the first place? Is the pump binding and pulling too much voltage? or??
81c3 is offline
Old 06-11-2019, 08:50 AM
CF Member
That was my first question. The tech stated possibly when the detail shop power washed the engine (ECM area) with it running it could have blown the fuse or the pumps could have blown the fuse? I drove it the detail shop & had it towed away.
Thank You
Michael
ps; now back to my 59 blown head gasket.
Quick Reply: 92 ZR1 stalls out
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
