1994-1995 AC decal
POSSE ZR-1 Driver
1994-1995 AC decal
Anyone know where I can get a replacement AC Decal that goes on the blower fan housing?
I need a new one for 94-95 134a.
I can't seem to find one in the usual Corvette parts websites.
Thanks.
Thanks.
Have some one with any '94+ C4 confirm that # is on the label. Get a snapshot and have it duplicated or do one yourself on appropriate paper and put a clear acetate label over it. Shouldn't require much of an effort. Doesn't need to be a ZR-1.
If above sticker is what you are looking for, I got it from Classic Industries - DC-1425.
Lettering is a bit skinny and part number on bottom right is different.
I am going to remove the original, try to restore the damaged left corner and see if it can be printed on sticky back film.
Woops! I re-read your post. Looks like you are looking for a decal on HVAC fan housing. Sorry!
POSSE ZR-1 Driver
Sorry. I searched all over google and classic industry web site but no luck.
when I go to Carlisle late August I will check and see if any HVAC fan housing for sale has a clean sticker. If I see a good one, I am going to see if I can remove and reproduce.
Lower right of the label I'd think there should be a part#. Either a match to the number I mentioned or something different. Did you look?
POSSE ZR-1 Driver
I have the original R12 decal on the '92, but since I'm switching to R134a, I want the correct label from 94-95.
I'm a little **** when it comes to stuff like that.
So you need to have Yun or someone with a '94+ C4 to check that label and see if there is a number there!!!
Radiator fan housing decals have different part numbers. Similar, not the same.
I'll try to get the part number with a mirror or something.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
The overflow tank is very easy to move out of the way without hooking the lines. I would get a pic but I'm also an R12 converted to R134.
