C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Driver headlight won't flip
Old 06-24-2019, 11:04 PM
medblueC4
CF Senior Member
medblueC4's Avatar
Default Driver headlight won't flip
I have a 1991 ZR-1. My driver side headlight won't flip up when I turn them on. If I flip it up manually it will close on its own when turned off. I replaced the motor and that didnt change anything. passenger side operates normally. Does that mean the control module is bad?
Matt
medblueC4 is offline
Old 06-25-2019, 09:47 AM
zr1fred
CF Senior Member
Yup... To test or run till the new part gets there run both lights off the good side.
zr1fred is offline
Old 06-25-2019, 10:31 PM
medblueC4
CF Senior Member
medblueC4's Avatar
So I ordered a headlight control module. Also when I came home tonight I plugged the driver side headlight motor into the passenger side plug and it did rotate in both directions. Installed motor in driver side. Now if I turn the headlights on passenger side goes up. Turn them off and passenger side closes and driver side flips up. It didn't do this before. Hopefully new module will solve it.
Quick Reply: Driver headlight won't flip
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
