C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Code 31 Cam Position Sensor
Old 05-14-2024, 06:30 PM
pappy.72
pappy.72's Avatar
Default Code 31 Cam Position Sensor
I have the dreaded code 31 service engine light code in my 90 ZR-1. I have checked the battery, alternator, sensor connection, etc. Anything else to check other than changing out the camshaft position sensor? Also, where are these available? I can’t find them anywhere. Thanks!
Old 05-15-2024, 12:41 AM
Will69camaro
Will69camaro's Avatar
Read on registry that someone had made a sensor from another engine work. Search on there!
maybe hit up mirrock too. They posted a ton of lt5 parts on eBay recently. Maybe they have the sensor.
Old 05-15-2024, 04:48 AM
pushrod-v8
pushrod-v8's Avatar
Google part number 55505-00-02-A credit due to Z51 Jeff for the discovery.
https://www.mouser.com/ProductDetail...SAAEgKBCPD_BwE
Old 05-15-2024, 05:26 AM
Z51JEFF
Z51JEFF's Avatar
[QUOTE=pushrod-v8;1607809534]Google part number 55505-00-02-A credit due to Z51 Jeff for the discovery.
https://www.mouser.com/ProductDetail...SAAEgKBCPD_BwE] Hold on,I dont think that's a direct fit. There is a member on the ZR-1 Registry site that either modifies these Mouser parts to fit or finds them elsewhere. I'll have to go back and check that original post or amend it. I did get one and it looked like it would work but the O ring didn't fit.
Old 05-15-2024, 08:02 AM
pushrod-v8
pushrod-v8's Avatar
[QUOTE=Z51JEFF;1607809545]
Thanks for the heads up. Here is your original post and information on the modified cam position sensor.
I have a spare one that needs to be grooved for the oring. Hopefully I will never have to use it.
https://zr1.net/forum/showthread.php?t=28584&page=8
Old 05-15-2024, 08:30 PM
pappy.72
pappy.72's Avatar
Thanks guys. I ordered one from Phil over on ZR-1.net. Messaged him last night and he is shipping it tomorrow. Hope it fixes the code and issue. If not it’s good to have a spare.
The following 2 users liked this post by pappy.72:
pushrod-v8 (05-15-2024), Will69camaro (05-15-2024)
Old 05-21-2024, 07:55 PM
pappy.72
pappy.72's Avatar
Hey guys. I just received a new cam position sensor from Phil. I got the old one out but WTH do you cram the new one in? It is not even close to squeezing in the hole. Is there a trick on getting it to slide in the hole? I have oil on the o ring, the hole is clean and smooth, and I have not even got it to start to go in by pushing it very hard. Any help or suggestions would be appreciated. Thanks.
Old 05-23-2024, 12:43 AM
pushrod-v8
pushrod-v8's Avatar
It should slide in. Have you put the two side by side to confirm they are the same size? Did you double check the hole in the cylinder head to make sure it's clean?
You may want to remove the inner fender well to get a better view.
Old 05-23-2024, 12:25 PM
Sleazy Rider
Sleazy Rider's Avatar
Do you have access to a set of calipers or a 0-1" micrometer and measure each one? All's it takes is a few thousandths of an inch to not fit and you are not going to see that with your eyeball micrometer.
Old 05-23-2024, 07:04 PM
pappy.72
pappy.72's Avatar
I oiled it up and wiggled it in. Still running rough and throwing the code 31. Phil said it may need a spacer washer to open the gap as the new sensor has a different pick up sensitivity. Will try to mess with it next week or just see if Marc Haibeck can take it soon. He is 30 minutes from me. Thanks.
Will69camaro (05-24-2024)
To Code 31 Cam Position Sensor
Quick Reply: Code 31 Cam Position Sensor
