FS: 1999 fixed roof coupe
6th Gear
11,000 cash
120k, new tires, hood shocks, trunk shocks, belts, both belt tensioner, a/c idler puller, coolant tank (sensor was broken). Car was aligned with new tires. Call or text 6019346674.. No Trades. Clean title in hand! PRICE IS FIRM! I did swap the gauges in the car. The dic buttons would not work. I attempted to swap just them, but the board was bad in the cluster. The mileage is stored in the cluster instead of the pcm or bcm. The cluster I installed showed 135k the car does have only 120k. You can send the gauges off and have it reprogrammed. The company I talked to was out of Michigan, and it would cost 175 dollars. It’s only 15k so it isn’t that big of a deal to me. I took the picture of the mileage when I swapped the gauges. That is the true mileage of the car. I have a walk around/idle video I can send if you text my number! Thanks for looking. Car is in meridian Mississippi.
