Lowest Cost Upgrade Path?
Forum,
I spoke with Chris at ECS (awesome guy!) about the ECS supercharger kit and my ultimate plans (insert evil laughter here) which is to reliabily produce around 700rwhp. I was planning to do this by going with an ECS Supercharger Kit(8rib) + Heads/Cam. Chris told me I would be insane to do this on a stock bottom end so I would have to go forged before going heads/cam.
Since I want to do this in stages what is the most cost effective path? Supercharger first, then forged, then heads/cam and driveline? or heads/cam, then forged, then supercharger? Maybe there isn't a cost effective path with FI?
I know installing things in stages adds labor cost but I will be doing all if not most of the work.
The complete timeline is about 1.5-2 years for everything (so the wife doesn't kill me)
The heads/cam kit I was looking at is the AFR 205cc with the Texas Speed Magic Stick 3 cam.
Thanks,
Mike
Thanks,
Mike
Originally Posted by chriswtx
With the ECS kit you will be able to hit 700rwhp with stock heads no problem
Damn addiction...
Mike
There is no cost effective way to go with FI...If you have to really watch your money, going FI will only end up being a headache. Read American HP's thread. His is a classic example...and he actually planned on spending quite a bit...you intend on spending a certain amount and it will always cost more...no matter what the vendor tells you. Just a part of the game.
If you do the labor yourself and pinch pennies..it can be done within reason. I have about $9000 in my car including the blower, Kooks headers, Corsa exhaust, cam, pushrods, dual valve springs, timing chain, new return style fuel system with Bosch pump, and MSD BAP. I have figured it will run me another $2800 to build a good short block myself with hand ported 317 heads I got off ebay brand new for $200 shipped and new Diamond pistons I picked up cheap for $400 shipped. I just take my time and shop for good buys. But for the non-do it yourselfer figure on about $18K when its totally done +- another $3K
Originally Posted by Earl H
I think you forgot the cost to upgrade the clutch or A4... oh, and last time I checked $9K was a good chunk of change.
St. Jude Donor '06
Location: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Building a complete FI package is very far from a budget build.
Oh yeah, the last 20% gets exponentially expensive whether it's the fuel system, traction, or the power system etc. In other words, 500rwhp can be had at a reasonable cost but a reialble 700rwhp is $.
Originally Posted by xtream1
Don't forget to add the tires to put the power down and rims to mount them on as well as a better clutch. Then there's the blown diff so add the DTE brace, hardened shafts, tunnel plate for chassis stiffness, meth kit, oil coolers, upgraded rad for the hotter temps, gauges, tuning, etc... Still haven't mentioned the incidentals inside the shortblock like head studs, timing chain, ported oil pump, gaskets, rockers, sensors, water pump, etc.
Maybe I should just go heads/cam and be happy
Thanks,
Mike
Mark
Like everyone else here price increases very quickly. Doing your own labor can save you thousands though depending on the shop. Also once you are at 500rwhp+ you will be surprised at all the Sh*t that goes wrong. In addition more Hp means more heat, as was mentioned above. You will need a larger radiator and/or cooler. Also tuning each time you change something, some charge $300-500 a tune or more. I have spent >$50,000 and its still not what it should be. You will read about clutches no holding up and of course A4 grenading.
Definitly not cheap and anything more then H/C gets into big $$$.
Doing all the work myself, mods in this order:
1) RAM 980 VDS clutch, alum flywheel, adj master, Z06 slave ~$1300
2) Used FLP headers ~$800
3) Racetronix fuel pump + wiring ~$300
4) Used LS6 intake ~$300
5) Futral F7 cam, Ti Retainers, Manley Double springs ~$900
6) A&A P1SC kit with 42lb inj ~$4900
7) FLP Dyno Tune ~$300
8) ECS Alky kit ~$500
Future:
9) Forged Bottom End
10) different pulley for P1SC :o
Future:
Life Time NCM #2196
Originally Posted by Z06GMAN
I didn't have a BUDGET ....
I did, however, make a plan and collected as many used parts as I could use reliably. When the collection was complete (about 2 years time) I did the install in one shot with some minor adjustments about 2 months later for the bugs (like adding a meth kit etc-they were still not quite on the market at that time). Now it's been three years/20K+ miles and I'm finding myself still making adjustments/alterations to sort out some of the lingering bugs...and I had a well thought out plan to begin with! I guess that's what happens when you forge new ground.
1 Post
St. Jude Donor '03-'06-'07-'08
I have the tires and rims (NItto RII's) and put the ported oil pump and incidentals inside the prices as well. I did not account for the drivetrain pieces though, so I will need to get prices on them.
Thanks,
Mike
Thanks,
Mike
Another way around this is to sell the stock car and buy a heavily modded car that was done by a reputable shop and check into the owner to see if the car was beat. You can get a modded car with mods at well below 50cents on the dollar.
Received 1,817 Likes
If you want immediate fun combined with cost effectiveness, do the ECS Paxton with the 8 rib. If you keep it around 500 rwhp for now and get the right tune, it should be pretty reliable and give you plenty of smiles until the money comes together for more.
