Pictures c6 single turbo 101mm rear mount
Premium Supporting Vendor
Well it looks promising. I would love to see a boost curve too.
That is a big turbo to spool up.
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Received 1,817 Likes
With a torque curve like that, I'd think it will be a bear to put that power down!
Originally Posted by Stangkiller
Nothing a lot of Nitrous can't fix though
It might be TOO big.. who knows really until you get it to the track. But I was looking for a TTiX curve to compare it too since that is what I have.
Like the water to air as well.
EDIT: Well I found what I was looking for... I will keep the rest of my opinion to myself, the setup is a neat idea and I hope it works out for you.. the workmanship is top notch!!! I don't want you to think I am downing your setup. Good luck and let us know when you run it.
The peak is VERY out there... the long pipes and the rear mount cannot be helping.
While I've yet to see a curve from a rear mount system that impresses me, the fact that the turbo is oversized for the application can't be helping things. Stick a 88mm turbo on there and I'm sure the results would be much more impressive. The lag will be greatly reduced and the curve will vastly improve.
Some nice engineering on the system as a whole though. One question, how is the cold plumbing routed back to the front?
We'll have to line you up with some Supras!
Originally Posted by kromberg
Please check me. Has the pipe be beaten with a hammer for clearance of the wheel
Keith
Originally Posted by rplaster
Beaten, hammered and cut, but if it makes good power who cares.
Supporting Tuner
I guess it just comes to what kind of work you want people to think you do. Some of that kind of stuff always gets touched up later in this one off stuff.
Originally Posted by AdvisorWanaB
I'm have to agree with the above statement.
Originally Posted by 1FastC61
The torque curve is specifically tuned like this due to the 6 speed and IRS.
Care to explain that?
This is a general question? Is it ok to have the fuel cell set up like you do in regards to safety. I mean without a fire wall of some sort or barrier. I ask because i was thinking of doing something similar with my C5. The problem is that the fuel cell will be right behind me and i don't know if this is a good idea? Thanks
Originally Posted by pianoprodigy
The power delivery would be extremely smooth and there would be no shock to the drivetrain.
So you put a 101mm turbo and you are worried about it shocking the drivetrain?
While you are trying to sneak up on me I will be waiting for you at the finish line...
