Blower cams
Old Mar 4, 2007 | 07:45 PM
sdnet's Avatar
sdnet
Default Blower cams
Hello all:
As you can see from my signature, I have a Magnuson supercharger on the car. I'm looking at what else I can do (while being street legal), and I'm considering the cam possibilities. I must admit that I don't know much about those. I understand that there are blower cams, which are designed to prevent the superchargers from leaking boost.
What kind of choices do I have, here? I am not necessarily looking for something extreme...probably something right in the middle.
Thanks,.
Old Mar 4, 2007 | 07:51 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We have a few cams that we use. We have both a cam that we designed for a centrifigal supercharger and one for a positive displacement supercharger (ie. Maggie). Feel free to give me a call if you have any questions at all..
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Mar 4, 2007 | 08:33 PM
FreddyG's Avatar
FreddyG
Chris, is the Centrifugal blower cam 918 spring friendly, and how much is it?
Old Mar 4, 2007 | 09:48 PM
Blue Lightening's Avatar
Blue Lightening
I have a Maggie and had ECS stick one of those blower cams in my Vette...The difference is significant.
Old Mar 4, 2007 | 10:24 PM
sdnet's Avatar
sdnet
What did it set you back?
Old Mar 4, 2007 | 10:51 PM
JJSC6's Avatar
JJSC6
I know what you can do!!!!
Try something called compounding utilizing an STS turbo in conjunction???
Seriously....let's see what this new Eaton TVS blower head unit can do!!!
Old Mar 5, 2007 | 09:07 AM
Cruise-In V Veteran
Yes we use 918's unless we are making a lot of boost (14 lbs) then we go to the 921's for the added spring pressure needed to keep the valves open
Old Mar 5, 2007 | 09:24 AM
Blue Lightening
I don't recall exactly what it cost but it was somewhere in between the first unborn and my wifes beagle.
Old Mar 5, 2007 | 10:25 AM
tlaselva's Avatar
tlaselva
Should be out later this year!
Old Mar 5, 2007 | 10:27 AM
sdnet's Avatar
sdnet
I will keep my eye on it, then. I will Google it, but does anyone have a link that explains it in detail?
Old Mar 5, 2007 | 01:42 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have ECS Blower 346 Cam. I was very impressed with the results so I chose that for my setup. Chris and Doug are the best!
Old Mar 5, 2007 | 01:57 PM
sdnet's Avatar
sdnet
Yup, I would probably go back to ECS if I didn't move out to Arizona last month.
Old Mar 6, 2007 | 01:16 PM
CraZee ZO6's Avatar
CraZee ZO6
how about bigger cams?
how would a ms3 237/ 242 600 lift 113 lsa or a cam similar work with a centri blower or turbo?
Old Mar 6, 2007 | 03:05 PM
Laguna Blu's Avatar
Laguna Blu
I have a 6+ year old cam installed that was put in with my original heads/cam package. Recently I had a Procharger installed on top of that package. I am going to have a blower cam installed but I am at or near the limit that a stock bottom end can handle. Will the new cam push me over the breaking point or will it just be more efficient to my FI setup? Of course Carmen @ The Vette Docs can and will answer this question but I do value some of the opinions on the forum as well.
Old Mar 6, 2007 | 03:33 PM
Cruise-In V Veteran
Hey Spencer, I would hold off untill you are ready to forge the engine. I would just enjoy the car the way it is and then when you are ready to turn up the boost you can go to a blower friendly cam.
Old Mar 6, 2007 | 04:48 PM
Laguna Blu's Avatar
Laguna Blu
Thanks for the heads up Chris. I was just thinking that it made sense to do it while I am upgrading my oil pump and timing chain. I guess that I'll have to talk it over with Carmen.
To Blower cams
