My car eats belts
Old Apr 8, 2007 | 06:14 PM
B-rent's Avatar
B-rent
Default My car eats belts
I just got a new belt put on in November, December annd once again the front of the passanger side belt is wearing off and 1 rib is already gone. Anyone else have this problem or any fixes? They are all new idler pullies and the belt is very tight according to my mechanic. Im waiting on new jack shaft bearings but Id assume thats not causing this issue correct?
Old Apr 8, 2007 | 07:02 PM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
Sounds like your pulley aligment is off. Did your installer use a laser alignment tool?
Old Apr 8, 2007 | 07:51 PM
B-rent's Avatar
B-rent
I doubt it, he runs a race shop out of his rear garage. All he works on is LS-1s so he know what hes doing, i just doubt he hes a laser
Old Apr 8, 2007 | 10:08 PM
B-rent's Avatar
B-rent
Is that something only a dealer could do? And any idea of a price?
Old Apr 8, 2007 | 10:10 PM
MotleyDrew's Avatar
MotleyDrew
If one rib is getting chewed up it is definatly out of alignment somewhere ! You need to check the alignment of each pulley !
Old Apr 8, 2007 | 10:36 PM
Honez's Avatar
Honez
What kit do you have? Did you contact the manufacture of the kit?
Old Apr 8, 2007 | 10:44 PM
longdrive70
Twin Turbo Coupe
I would call Carolina Auto Masters as they are not far from you. They are a very reputable performance shop. The dealer will not be of any help to you. This is would be a simple fix just requiring proper shimming of the pulleys that do not line up
Old Apr 9, 2007 | 12:47 AM
Tsab's Avatar
Tsab
Sounds like an alignment problem. Buy a Gates Lazer alignment tool they are not that expensive and pretty easy to use.
Old Apr 9, 2007 | 08:55 AM
B-rent's Avatar
B-rent
Yea it starts as just the most forward rib and once thats gone it starts tearing away at the next one. Im not 100% sure it can make it to Durham for CAM but I might look into the laser or worst case give durham a try
Old Apr 9, 2007 | 09:12 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Alignmnet
You sre defently out of alignment, get a Gates Alignment tool and you will be able to tell where it is
Old Apr 9, 2007 | 09:22 AM
B-rent's Avatar
B-rent
You think it would be something I could fix too? Im not all that informed on engines but I know how to turn bolts and ive put belts on my Jimmy before
Old Apr 9, 2007 | 09:49 AM
corvettetimmy's Avatar
corvettetimmy
Hope you get the problem figured out..
But I do know that Advance Auto parts has 1 year warranty on belts. They might have to order you two to start with, but you wont have to buy any more for a while....
Old Apr 9, 2007 | 05:33 PM
B-rent's Avatar
B-rent
I think im going to order the Gatorbacks this time from them. I just have to decide now if I wanna spend the $100 on the laser and hope i can figure it out, or just pay the stealer to fix it
Unless someone wants to let me borrow thier laser and ill pay shipping both ways?
Old Apr 9, 2007 | 05:43 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Get that baby aligned and all will be ok and you will not be chewing up belts
Old Apr 9, 2007 | 06:03 PM
B-rent's Avatar
B-rent
Anyone know off hand the GY Gatorback belt size? vortech said i need the 104.5 in belt and i know stock is like 86.25in(or close) I just wanna double check before I order 2 new belts
Old Apr 9, 2007 | 06:09 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
What size pulley are you running on your blower?
Old Apr 9, 2007 | 07:31 PM
B-rent's Avatar
B-rent
No idea I count 6 ribs on the belt if that helps
Old Apr 18, 2007 | 10:48 AM
B-rent's Avatar
B-rent
Ended up having the dealer do it cause the supercharger has to come off for new belts. Any idea what I can expect to pay for the idler pulley alignment? I know its $200 for the new belt to be put on
To My car eats belts
