IAT Relocate...Wiring Questions
Ok, I have already used the search function as well as going to ls1tech. I am wanting to relocate my IAT after the maf and the alky nozzle. I have an 03 zo6 with the IAT integrated into the unit. I have the IAT sensor and the wiring pigtail from a few part numbers that I was able to find on the net. My main questions are as follows:
1. Can somone post a picture of what wires need to be used from the maf itself and what color are they on a 03 z06?
2. Do I just cut the 2 wires off at the connecotor and attach them to to sensor?
3. Is there any orientation that wires need to go in? Is one a ground?
4. Does anyone have a link or something with a how to?
Any help would be greatly appreciated.
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Contrary to the maggie instructions, but according to my factory manual, cut the tan wire and also the purple wire (maggie says black w/white)
It works with either the black/w or purple, but the actual wires are tan and purple.
No polarity, so just hook your 2 wires to those 2.
You do have to cut the tan wire though, or the MAF IAT will still be sending a signal. You could just splice into the purple wire and leave it going to the maf...your decision
Same car , same year....
St. Jude Donor '08
