STS Install Manual - Can this be emailed?
St. Jude Donor '11
can I please get the install instructions as well , I seem to have misplaced mine thank you katherinescharter@yahoo.com
2nd Gear
STS install PDF file
Been thinking about one of these systems also, would someone please send me the file. Thanks in advance... Cruiser69@comsouth.net
I know it's an old thread but wanted to see if anybody could email a copy albertozco@gmail.com. thanks
Would someone please email this PDF file to owb108@hotmail.com C5 STS Twin turbo Install PDF. Thanks!
Rear mounted turbos
This post sure seems to be showing a regained interest in the rear mounted turbo system. A few years back this system was so hated by a lot of members on this forum.
I had bought (new) and started installing the STS system at that time, I never was able to get the turbos to hang to were I felt comfortable, and I also had issues with the duct work going through the rocker panels.
I took it apart never having run it and ended up buying a A&A YSI kit.
#33
It's a kit that has it's pros and cons, if I knew how hard it was to force the pipes up the rocker panels I may have had second thoughts lol.
I was able to get a copy of the manual btw, I found my hardcopy in a box in the garage. I also now have the pdf.
#35
I am thinking about going back to a STS kit only due to the fact that I miss having the all the engine bay space. It is one of the simplest kits and it does have its pros and cons as mentioned earlier. I have a copy of the manual but it is from a decade ago and I am wondering if this 77 page that is circulating is the same one. If someone can email it to me i would appreciate it
InlandTechnologySolutions@gmail.com
