Intercooler for Magnuson
Old Mar 8, 2008 | 05:12 PM
DeJay's Avatar
DeJay
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Default Intercooler for Magnuson
I would like to know if anybody makes a radiator-type intercooler for a Magnuson Supercharger? The reservoir that holds the coolant for the intercooled Magnuson is kind of small, and I wonder if a radiator-type intercooler mounted near your radiator would ease the heat-soak issue with the Maggie. Anybody know anything?
Old Mar 8, 2008 | 05:35 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
well first off you are talking about the heat exchanger as the intercooler is under the maggie i relocted mine, there is a post on this and you can get a bigger 1
Old Mar 8, 2008 | 05:38 PM
RonVette2's Avatar
RonVette2
Here is mine I just had installed with the Maggie recently.
Old Mar 8, 2008 | 06:41 PM
robert miller's Avatar
robert miller
RON, That really looks good. hope you get the car back soon,And it really should come on fast. Man you just cant bet the meggie,s low end tq can you..
Old Mar 9, 2008 | 10:31 AM
Vega$Vette's Avatar
Vega$Vette
There is a Radiator-type intercooler mounted in front of the radiator on intercooled Maggie set-ups.
Even after back to back runs the temp of the coolant in the reservoir is luke warm at most.
Short of adding Meth there is little you can do to lower IATs.
Bigger radiators, pumps, license plate/screen cutout etc. do not really make a difference in IATs as the limitation is with the size and efficiency of the heat exchanger located under the blower.
BTW My setup works perfect with the "stock" as designed by Magnuson installation.
Old Mar 9, 2008 | 10:51 AM
2002 MATRIX SC
again the little radiator thing is a HEAT EXCHANGER the intercooler is under the maggie
Old Mar 9, 2008 | 11:11 AM
Vega$Vette's Avatar
Vega$Vette
An intercooler is also heat exchanger.
Technically anything that transfers heat from one source to another is heat exchanger.
However for discussion purposes we will refer to the exchanger under the Maggie as the intercooler and the radiator as the heat exchanger.
To Intercooler for Magnuson
