AF ratio/plug question
Old Aug 23, 2008 | 01:42 PM
TurboTravis's Avatar
TurboTravis
Default AF ratio/plug question
Guys,
Here is a 'log' of my TT ZO6 at 12psi, with meth injection. The plugs come out looking IDENTICAL to brand new plugs right out of the box with no signs of detonation, etc and the engine compression is solid at 155psi across the board. The 'lean' spot from 4500-4900 initally scared me, but the builder assured me it was fine. Just curious what you all think and if you guys' plugs look similar to mine. This is on a forged shortblock with dart heads BTW.
Travis
4000rpm-11.9
4100-11.7
4200 11.2
4300 11.2
4400 11.8
4500 12.5
4600 12.4
4700 12.5
4800 12.4
4900 12.4
5000 12.1
5100 12.2
5200 12.1
5300 12.1
5400 12.2
5500 12.0
5600 11.9
5700 11.8
5800 11.8
5900 11.8
6000 11.8
6100 12.0
6200 11.6
6300 11.7
6400 11.5
6500 11.2
6600 11.2
Old Aug 23, 2008 | 10:43 PM
TurboTravis
Thanks everyone!!!
Old Aug 24, 2008 | 12:02 AM
Jake@EPP's Avatar
0Jake@EPP
Former Vendor
The lean spot should be fixed to the 11.5 area. Being in your torque area, this is even more critical. Depending on cylinder pressure, all it takes is one rattle and shes gone.
Old Aug 24, 2008 | 01:07 PM
leojnknsC5's Avatar
leojnknsC5
Old Aug 24, 2008 | 01:50 PM
RoadRebel's Avatar
RoadRebel
What gear what this pull done in and what conditions? What is the data derived from, built in wideband or?What is the average airfuel at cruising? That would give me some back ground as to what that info really means. Passing judgement on this info without the requisite background information is futile.
Old Aug 24, 2008 | 02:08 PM
TurboTravis
This was in 3rd gear @WOT using FJO datalogging software. Last night I turned up the boost to 13psi and it got slightly richer but it's still in the low 12's in spots.
Old Aug 24, 2008 | 05:59 PM
RoadRebel's Avatar
RoadRebel
I would pull it from 3500 through that area in question in 4th gear. I think you will find its fine. Also look at idle/steady state cruise airfuel. Often there is an offset in readings one way or another that needs to be taken into account.
Old Aug 24, 2008 | 06:11 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
You sound like "Obi One Canobi".... Your efforts are FUTILE........
Old Aug 24, 2008 | 08:08 PM
TurboTravis
The car cruises at 14.7. I'm going to play it extra safe and get the car retuned to low 11's just so I have a wide safety margin for climate/altitude changes, etc.
Old Aug 25, 2008 | 08:20 AM
TurboTravis
Why would you think it would probably be fine?
Travis
Old Aug 25, 2008 | 08:29 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Hotter plugs will be white when you pull them out. They will burn off the contaminants. What plugs do you have? TR6's or colder I hope.
Old Aug 25, 2008 | 09:13 AM
TurboTravis
TR6s. Actually, only #7 looks white and the others are starting to show some color.
Old Aug 25, 2008 | 10:52 AM
Mike@G-Force's Avatar
0Mike@G-Force
Former Vendor
The man knows what hes typing. Peak Torque is the danger zone.
Old Aug 25, 2008 | 12:17 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
As stated above....get the A/F down at peak torque - if you could manage 11.5 straight across that would be wonderful.
Old Aug 28, 2008 | 12:30 AM
INTHERED's Avatar
INTHERED
How long have the plugs been in the car ? Sometimes it takes a while before a new plug gives you an accurate reading.
inthered
Old Aug 28, 2008 | 08:51 PM
Rkreigh's Avatar
Rkreigh
He IS obe wan when it comes to the tune
Help Me Obe Wan, you are my only hope
the type of wideband and location as well as other factors can throw off the readings. the most accurate is up front generally
Phil does a great job tuning!
To AF ratio/plug question
