Another Maggie Question from The Yav
Gentleman,
Will a Maggie bought for a 98 work with a 00? Remember the dual fuel lines (If I rememer one was a return) on the 98 model. Is it the same part number for a 98 and a 00? Thanks for your response.
v/r
THEYAV
v/r
THEYAV
Worst case scenario, you would probably only need to join the 2 fuel rails. They have 3/8 pipe thread on the ends I believe (maybe 1/2 pipe), so it's no big deal. Just join the rails together and tie in to the drivers side one.
Yes, they (Maggie) make an adapter to change over to the one line system!
I had to change mine over to a two line set up for my 98...
I give you my old one line adapter if I knew where it was!
You may have to go thru Cllaway to order it........
