Pulley alignment tutorial
Was that the first belt you break or has then been others ?
thanks,
Ed
Here is a pic of the PS pulley after grinding and sanding the back side down. I also ground the high spots and the ridge on the power steering pump body to make sure I could achieve the depth I needed.
Giving you a heads up.
Keep an eye on that POS billet power steering pulley as I purchased the same one. I had to grind down the one shown below on my bench as well. Note its the same one you have.
It has the wrong offset for a C5 or C6, it's way off. We should not have to grind off almost a 1/4 inch to make it fit.
When I was re installing it after grinding the back as you did, I noticed it went on easier than the first time and gave me an uneasy feeling. It proved to be a problem I should have addressed as the pulley slowly walked off the power steering pulley when the car was running as I was tuning. I was hanging on 4 ribs of an 8 rib belt, that is how much the pulley walked out. I was lucky it didn't fall off completely and start shredding things.
When I purchased it it looked like a nice piece and thought it would save my customer $115. It was $185 vs. $300 for the ATI one.
Well, I guess you get what you pay for.
I Toasted a $55 belt, I'm out the $185 for the Billet pulley and the extra labor re installing it which is a PIA (remove ABS unit, sway bar ,bleed brakes again etc.). plus purchase the $300 ATI pulley.
The ATI one is shown in the kit below.
The ATI unit has a STEEL HUB like the OEM unit instead of Aluminum like this one. It went on much much harder than the aluminum, even the first time I installed it. All you have to do to line it up is press it in until it bottoms out on the power steering pump.
Not sure exactly how differently the C6's are set up, but I was able to remove the bolts for the alternator bracket and raise the assembly up to get my removal and installation tools on the P.S. pulley. I have never had to remove the ABS gear.
I am enjoying following your build by the way.
You and Andy will get it all figured out and it sounds like your begining the end game once again.
Congrats on an awesome build!
So how far are you from Houston?
Ok, maybe not, but maybe if I get a good Canon digital camera I'll be there but I'll have to figure out how to use PS3.
Andy has been awesome to me from day one. I feel like family now that he likes to verbally abuse me when I call. ( only in jest for those of you that don't know Andy Green )
I am 4hrs north of Houston, in Kaufman county which is one county east of Dallas.
Not sure what you mean by custom guide, roller like. The alt and P.S. do pulleys have high edges to help keep the belt in place though.
like make a braket and atach it where the pulley is and make it like L shaped so it holds the pulley down so when it tries to jump the guide does not let it... I have it in my head but its hard to explain maybe ill draw it ad ill send it to you.
But pretty much like a tensioner on top of the pulley. But the belt doesnot wrap around its purpose is just to keep the belt down in place.
This is just an Idea.
Ed
I also ordered another 2.95" pulley because I originally put the Reichart on backwards and pinched it between the S/C and the tensioner. I straightened it out, but I want to eliminate all possibilities. I noticed that the new pulley (not a Reichart ), has higher edges. if this problem was occurring at the supercharger, this might help eliminate that as well. The spacers should be here tomorrow and I will work on getting everything back together this weekend. Keep in mind that it took about 500 miles for this problem to rear it's head, so it may be a while before we know of my success.
We followed the same path as ATI.. We just couldnt justify how they were charging soo freakin much.. Ours include, Steel hub, hardended bolts, and CNC pulley..Our pulley kits also have the option of CNC'd steel or Aluminum.. We not only offer them in chrome, but hard annodized black as well..
Plus their half the price as the ATI kit... WITH a free replacement bearing warranty..
Will definitely keep you in mind for future builds.
