LSX 434 Twin Turbo Project! PICS!!!
St. Jude Donor '08
6 Bolt
1a - That's what I'm trying to get informed about. I understand that the Warhawk, LSX & Dart billet blocks have provisions for 6 head studs/cylinder & that's the #1 feature ( clamping power to prevent head lift ) that has my personal interest. It's a given that all 3 of these blocks can be bored & stroked for greater displacement so I'm trying to accumulate all the info I can before making my own decision should finances permit.
Just gotta get this stupid stock market to turn around!!
G
G
G
G
For the power that thing can make, I would go with a carb style intake rather than a sheet metal one. The carb style intake will create a more even distribution of the charge across all the cylinders. Even on FI application, you can still lean out the #7 and #8 cylinders. If you are making big power, leaning out a cylinder just a little bit can lead to major problems.
#33
PICS of new RPM stage V Tranny and RPM stage V Quaife differential. It's a 3.08 gear differential. Why so high? With my power band being in the 3000 to 6000 RPM range I need control over the rear tires as "breaking loose" is a big problem with these fast spool turbos.
BURNING OUT OLD BUSHINGS REPLACING WITH ALL POLLYS.
MORE PICS TO COME!
MORE PICS TO COME!
#34
^ Nice work.
It's a lot easier to push the bushings out with a ball joint press. Make sure you wash down all of the parts really well and clean the inner sockets of debris, Wipe them down and use a lot of the poly grease.
I have mine on for over (2) years no squeaks.
