Methanol trunk mounted tank pictures please
Anyone who has their meth tank/pump mounted in their trunk id liekto see pictures. You have it mounted down in the large cavity space or on the flat surface in front of the smaller cavity? Its not gonna sit flat on the bottom area with supplied mounts so some sort of tray is gonna have to be fabbed up or not use the supplied mounts and fab up another strap of some sort ringed down.
Here's some pictures of mine when it was mounted in the trunk. I have subsequently moved it to the windshield washer tank up front since I relocated my battery back there.
Hidden by cover:
Partially open cover:
Mounted with custom plate provided by RPM motors:
Here's the relocated controller in my ashtray:
Hidden by cover:
