Introducing our C5 Single Turbo Kit
#41
Only thing that would be of concern to me, would be heat management considering the turbos location.
#42
May be heat extractor hood would help, i saw on big auction selling for 639.
So A2W is more efficient than A2A ? if so its good than but it adds the weight of 3 gallon water as he said but who cares little weight when u can get lot of power comin from turbo.
#43
Received 1,817 Likes
#45
St. Jude Donor '08-'09
I have no heat issues with my setup and have taken trips up to 800 miles in the summer.Key is tieing everything up properly and some heat insulation.I even run the stock overflow bottle.The turbo blanket on the exhaust housing makes a big difference.As far as the air cleaner it looks like Hinson has notched the rad cover for a 90 degree duct.As I posted before I got rid of that setup and dropped the rad for lots of clearance.
#46
Earl had heat problems, etc...
You have to keep in mind that he had the Cerra kit and they went under leaving no support.
Earl moved onto a bigger motor, TTiX SYstem and conversion to an auto trans that Dr Phil installed.
I had the pleasure of meeting both of them on one of my parts gathering mission over at Phil's house.
With all of the newer products and support info out here, I don't think it's as big of a problem today as it was back then.
There are quite a few PTK / Halltech system out there running just fine with the proper insulation and wiring routing.
A good turbo blanket and some heat coating will help a lot. Of these wear items do cost a bit, but how often will you need to change out the blankets.
The TTiX and APS systems do away with these extra's but then you have to deal with other issues. All of these systems are a compromise and you just need to educate yourself on the pro's and con's of each and figure out what you want.
#47
I ran 11.2 @ 127 with a dead stock LS1 including stock exhaust.T70 turbo.That was right off the street with a mild tune and pump gas.If I had a stickier tire I know it will go 10s.I was at 8 #s of boost and I think it will handle 12-14.
#48
St. Jude Donor '08
I am wanting to go FI before or the beginning of summer and was set on a centrifugal SC setup and this made me think also.
I already sent my tuner a message and he gave me very good advise on this kit.
I just like the idea of a big single and its definantly different. With different comes cons also though. Itll be a little while longer before Im ready so Ill be keeping my eyes and ears open on this kit
#49
Six-Speed or Auto ?
Thanks Tony for taking the time to to explain that.
Just lucky to be in the right place at the right time.
#50
I wonder if it'd be cheaper with A2A intercooling? I'd think so because you're taking the circulating pump and the heat exchanger, but that's my uneducated guess! I like the simplicity of the A2A and without a circ pump, that's one less thing to possibly go wrong. Please bare with me, I'm just thinking out loud!
You're Welcome Elvir!
That's Great for just bolting on a turbo setup!
What tires were you on?
#51
#53
i really think that its only small things that are needed to make this kit better and very reliable.
-coating the turbine housing and downpipe or getting a turbo blanket and wrapping the downpipe.
-wire routing and keeping the wires away from the heat
-aluminum coolant resevoir
-matching driver-side manifold
-intake system to work with the setup and rad support drop
stock hood with the coatings on everything or everything wrapped should be good enough i would think.
i cant wait to get my hands on one of these kits tho.
i wonder what the price for this kit with upgraded t76 turbo, coolant resevoir, fuel system and shipped to my door in ohio would be and i wonder how in-depth this install would be. should be too bad i wouldnt think
#56
#59
IS fuel rail covers and coils can be at original location or it will be too much heat from turbo and its down pipe will melt them? i like to retain coils and FRC's in place where its now.
Dominic: any fabrication to be needed when u installed A&A intercooler.
I have a Dewitt radiator so will it fit or had to switched to stock OEM radiator.
Dominic
